damn procharger, i need help!
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
okay so i finally got the belt to stay on, i took her out for a spin, 1st i'm only getting 6-7 psi of boost i wanted 10lbs, man what a difference with the supercharger! i love it, except i come home and theres clouds and clouds of bluish/white smoke coming out of the exhaust, i followed the procharger instructions except i left the pcv valve attached. the FMU is set at full rich also, the motor never smoked a drop and has 9k on it, anyone else have something like this before? is it sucking oil in somewhere?
Car: Used to drive a camaro
86Z, how do you think you blew the motor? When you were running the 6-7psi boost did you notice your fuel pressure? It should've been 70+ PSI. You may have run really lean if you did toast a piston or such. Again, what makes you think you blew rings / engine?
Car: 1986 Camaro SC
because now when i bump the starter i heard a bang and then the starter grinded, when i manually turn the supercharger the engine will turn then stop and the supercharger belt slips on it
1 Post
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
I hope its an easy fix... *fingers crossed*
Car: 1986 Camaro SC
well i dont understand what went wrong, it was a healthy motor before the supercharger, oh well now i have an excuse to build the 350 roller block on the engine stand
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
86Z. Did you change the oil before you ran it on boost? If I remember you were having a heck of a time tuning an over rich idle. Probably diluted the oil real bad with gas. Can't lubricate the walls very well like that. Have you pulled the plugs yet?
FWIW, I justed ditched my 749 for a FAST XFI. I got fed up. It ran good but not good enough. My pops works at a machine shop in CT, if you need some help, let me know.
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
OMG thats sucks!! Keep us posted on whats wrong. Like the guys said what was your fuel pressure, what do the plugs look like, is the nose of your crank wobbley?
Car: 1986 Camaro SC
well the fuel pressure was set at 43psi at idle, i had a fuel pressure gauge on the fuel rail which did me no good in the car, i have an electric in car on the way, the gauge only went to 60lbs and is now not working possibly due to the fmu spiking more pressure, i did not change the oil and it does look kinda thin, damnit it's probably my fault somehow, it was my first time with boost, i'm gonna look at the motor tonight after work, i need a 350 recipe for tpi and boost
Car: 1986 Camaro SC
guys, update, i pulled the valve covers, everything looks good, i pulled all the spark plugs, when i got to cyl 6 fuel poured all out onto the ground i mean a lot, i mentioned before that the fuel pressure gauge was not reading no more, so for haha's i turned the key to the on position fuel pump kicked on gauge moved slightly and dropped i then turned the motor over by hand and fuel poured from the same cylinder again, these are brand new ford motorsports 30lb/hr injectors, is one of them bad and thats why it's not holding pressure? the better question do you think anything happened to the motor driving it with the supercharger for a short while and not firing? the plug was really wet with gas...
Car: 1986 Camaro SC
87tpi we should hook up sometime this summer, i hope my motor is okay, i think i'm gonna go with the dfi 7 instead of this fmu, i didnt have any luck with the 7749 neither.
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
You should also check the fuel rail pressure regulator. It is possible that it's diaphragm ruptered and that would pump fuel through the vacuum hose and into the intake manifold. If this were your problem, the fuel would probably go into more than just the #6 cylinder, so maybe it is an injector. But he FPR is so easy to check, you should do it right away (just pull the vacuum hose off of it and turn on the key- there should be no fuel coming out of the regualtor vac hose).
Keep in mind that if the FPR diaphragm was weak, the higher fuel pressure from the FMU could have done it in. I had this happen to me personally, so check it out. And be sure to change the oil before you boost again
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You could test the cyl #6 injector by setting the #6 piston at TDC and applying +12v the the fuel pump via the ALDL connector pin or the fuel relay. If the injector is leaking bad enough you will see fuel pour out of the spark plug hole. Oil change after that.
www.megasquirt.info might be worth a look. Some people in the ECM board talk about it and seem to like it. I don't think it will run the coolant fan with the stock code though. Doesn't have the TCC code either.
Car: 1986 Camaro SC
it's the #6 injector leaking like a pig, i took all the injectors out, theres fuel everywhere, the plenum and the procharger air inlet at the throttle body, the afpr looks fine
Engine: 5.7L
I just pulled out some 30's barely run, If you need to borrow one until you get a replacement let me know. If you don't live too far away possibly we can hook up.
Motor is probably ok as long as it didn't hydrolock, you can either bend the rod or pound the rod bearing into failure. I actually had the same happen with a FPR rupturing it filled the plenum with fuel, I caught it pretty quick. I've also had a customer's vette bend a rod when trying to start the engine with a cylinder full of gas.
I have been told the Gen 7 is on a bad backorder, no release date published. I think Megasquirt II would be a nice set-up with wideband, I heard it does auto VE corrections based on AFR in closed loop using the wideband, but I haven't confirmed that it does. Would be nice if so considering the cost of the others.
Yea, the 749 performance isn't what I was looking for. I'm kinda picky and IMPATIENT. I just did the low z mod with 65pph injectors, that didn't make me happy either. I'm not giving up, I have all the hardware and software for chipping. I plan to practice on some stock apps. I'll retry the 749 some day after I learn a lot more. Keep in mind I have been running $58 for three years and still haven't gotten it the way I want it. Performance should not be accompanied by sacrifice and environment irresponsibilty. Now I'm no tree hugger but my efi motor should run cleaner than a tri power big block with no cats in 1960 something with a bad misfire. I punched my own hole in the ozone right over my house trying to tune my idle ve tables for the last three months.
Car: 1986 Camaro SC
lol, well i'll have to figure out what ecu i'm going to go with, as far as i know i noticed the smoke right when i pulled in front of the garage, the only thing that concerns me is i tried turning it over afterwards and i heard some kind of bang and then the starter made it's grinding noise i hope the rod is okay, guess i wont know until i fire it up again, i'm gonna have to get some new injectors i'm not waiting for summit to figure it out
Engine: 5.7L
Summit, good luck. Any time I had a warranty issue with them, it was buy another one & send back the defect, if it is defective then we will reimburse you. Always a PIA. Not that I think summit is bad, just the warranty stuff stinks. Like in your situation, you need one injector. They won't just send you one, unless you pay or send the old one back, like you're beating them out of one injector for that screaming 9 cylinder you're building. I had a problem with an Accel injector I got from them and thats how they handled it. I had to buy a whole new set & send back the old ones. I did get credited so its not all bad, just a pain. My 30's are just sitting on the shelf, if you need to borrow one, don't hesitate to ask.
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
ok ima little lost, what happend? im lookin to get an ati and ive never installed a supercharger, this is kinda scaring me away. sry about the car man.
Car: 1986 Camaro SC
i had an injector go bad and i'm worried that i bent a rod from it dumping all the fuel in the cylinder, waiting on new injectors, was no fault of the supercharger.
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
FWIW, I justed ditched my 749 for a FAST XFI. I got fed up. It ran good but not good enough. My pops works at a machine shop in CT, if you need some help, let me know.[/QUOTE]
Not to change the subject.... how do you like your FAST XFI??
86Z, I'm sure your a little less stressed out now knowing the engine is good. Curious though, engines typically dont' make a "bang" sound in a good way. Were you able to find out what it might have been? Also, are you planning on going back to a $58 code anytime or are you sticking wihth 8d?
Car: 1986 Camaro SC
the bang wasnt really loud, i think the engine may have kicked back i'm not really sure, all i know is it doesnt make any noise and compression is good, is it possible that some fuel ignited in the exhaust seeing the cylinder was full of it? i am going to try $58 again seeing as the weather is getting nice and i have some time off, i definately would like to control my motor under boost.
Car: 1986 Camaro SC
also i took the pcv off vacuum now the breather on the pass side valve cover emits oily smoke, why is this?
Yes the MS-II unit will do auto correction of AFR based on the WB sensor, and the install isn't too bad especially on a TBI/TPI type engine. I tried to do something similar on a motor of mine with the fuel, luckily I didn't trash it though. Drained a good 7-8 quarts of oil/gas out of the stock oil pan, that was a lousy day to say the least. Good luck with what ever you do.
Engine: 5.7L
Car: 1986 Camaro SC
yeah my uncle says the pcv will probably slam shut, there wasnt a lot of smoke but i was at idle at a stop light and saw it come through the hood a little bit, i'll put it back on as it did not do it before
Car: 1986 Camaro SC
you've broken some rings or ring lands and are getting blow by
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
then my compression test would show that, which it didnt.
