snow meth/water injection
Car: trans am
Engine: sbc350, afr 180cc head, comp full roller, xtrem 276,comp 1.6 roller rockers,weiand142
Transmission: tremec tko
Axle/Gears: 8.5 3.73 gear, moser 30 spline axles,eaton posi
well i was thinking of running a small shot (50) of nitrous with the weiand 142 at the track only, but am thinking that this kit/method is the way to go. just wondering what you guys think of this kit or other water injection kits out there. i think it would be great for a roots blower due to the heat it makes and being able to run boost with more timing. so let's here it fella's.
thanks -brian
here's a link to the kit i had in mind www.snowperformance.net
thanks -brian
Car: trans am
actually good thing you brought it back -lol i have finally bought the meth/water kit and installed it on my roots blower. what i did was i made a bracket to mount on the carb stud and hold the nozzle. i made the bracket so the nozzle shoots it into the secondaries. it got to cold here for me to use it so looks like next summer will be the true test. i tried it at the track two weeks ago but with the cold air the water kit bogged it down. any more questions or need help drop me a line
