F1R and KB hypo pistons & race fuel?
Car: 88 iroc z
Engine: 388ci
My 383 ci. combo consist of a custom comp hyd Roller with 258/262 at .050 and mid .550 lift 4 and 7 swap cam 112 lobe sep.(dont remember correctly on lift )with 1.6 rocker, mildly ported edel vic jr. heads, vic jr intake, KB hyperutectic 134 flat tops with total seal gapless second rings. gapped at aprox .032 top ring. quench was set at .045. 410 gears and 3600 9.5 lock up conv and of course a 700r4. Compresion is around 10.1. I am installing a Procharger F1R + aeromotive fuel pump, with no intercooler and wanting to run 12+lbs with my current set up. Will 110 race fuel keep my set up alive (rev limiter at 6000rpm) What carb should I use? suggestions welcome!
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
