DSM 14b turbo on a 305/350
Car: 91 Z28
Transmission: 4l60e
k guys a friend has a turbo and intercooler off a turbo talon and would let me have it for free i w as just wondering would if be big enough to build boost on a 305 or a 350 if so how much you think i could push?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
sure if you maybe grab at least two of them. only other way it might help is if you are running such a low boost but I doubt that turbo is going to be very efficient either way
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
if its free take it, and find another one in a junkyard or something.
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Iagree .....or hit a DSM board ... probably find a good one there.
You can find one for $100-$150 in good shape, look on DSMtrader.com, or cheaper in the junkyards. Also pick up another IC and use 'em both.
Just one is way too small, two would work decently on a 305.
Do a search and read the stickies for tons more info.
1 Post
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Yes, they are very small. I think two would barely work. Probubly not worth putting the work into it.
dustint209
11-26-2015 12:28 AM
