spark plug gap for turbo
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
For a forced induction (turbo) engine is it better to have a small sparkplug gap(035-045) or a wider one(050-060)? Does it depend on the temp of the plug or what? I want to use Bosch Platinums.
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
WHat does the car fell like when the spark gets blown out? I'm assuming you get high speed mifires, but is there any other signs?
Oh yes, I second the what you said about the tight gap. I run my TT IROC down to .030", even with an MSD. Have never tried larger gaps though (I may be able to open them up a bit for my mild boost).
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
it feels like a mild version of fuel cut, or if you put a few of the plug wires on in the wrong place and tryed to run high rpm
Engine: electric
Axle/Gears: 10 bolt
I got a little of that drag racing my Turbo Z24 the other night. It also popped a ittle out the exhuast. The problem only seems to be present at above 8psi of boost and high RPM. I was thinking it may be 'blown out' spark. I'm def going to wide-band it again- if the AFR is cherry, I'm going straight to the plugs. I was running .040" for over 5k miles now on the 3400, so I'm thinking some ignition misfires may be occuring.
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
So for say around the 6psi mark on a stock-ish motor, we are agreed on about 0.030"?
Sounds reasonable I think.
I run .028 in my Talon with up to 24 psi, but it's stock ignition system is fairly healthy from the factory.
I was blowing out the spark occasionally at 7000+ rpm on 21 psi when I had worn plugs that had opened up to ~.032.
I know it's not a small block Chevy but good for reference anyway. I'd think an MSD setup on a small block should be at least as strong as my Talon's stock ignition.
evilstuie
02-28-2016 03:33 PM
