Where to mount the blow off valve
Old 06-20-2005, 06:00 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
For now Im running a MAF on my turbo setup. Where should the BOV be mounted... before or after the MAF?
If I let the BOV into the atmosphere wouldnt it need to be before the MAF before the air gets measured... and if I plumb the blown air back into the intake it would be mounted after the MAF... Am I on track with this thinking? Any preferrred method?
Old 06-21-2005, 07:21 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
With a MAF system you run the BOV after the MAF....then the discharged air back into the inlet tube before the MAF..
Pretty much any other way will cause problems...
Having messed with this before the best advice I could give is DITCH the MAF ASAP... that system on mine was a PITFA to set up and worked no where near as good as it did when I could blow off to the atmosphere..
Old 06-21-2005, 06:01 PM
TGO - 10 Year Member
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
huh? you want it all to happen before you meter the air. so if you have your maf before the compressor you just route the air back to the inlet of the blower no problem. same amount of metered air in the system
if the maf is before the throttlebody but, after the compressor then you can vent the extra since the maf never metered it yet so it has no way of knowing
Old 06-21-2005, 08:32 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Yup... Your rght..went back and looked at a pic of mine...It went from discharge tubing to the elbow right after the compressor..
Rusty memory on my part..
But still scrap the MAF... the strupidest part of the system was the fact that you needed reducer couplings to plumb the puny maf in...my car ran much better map..
Old 06-21-2005, 08:51 PM
lock's Avatar
Car: 86 IROC-Z
I hear you on the MAF. This is phase 1 of my project. Im new to power adders so Im taking it slow and only plan to run about 6# initially... then Ill get into intercoolers, ditching the MAf, etc
So to make sure about the BOV placement... I can put it here in this current setup? (circled in red) I went with a Tial... damn the thing is huge!
Old 06-21-2005, 08:57 PM
Engine: ls1, LB9
yes, correct
Ghettobird52
07-05-2024 11:18 PM
deracer
04-11-2016 12:04 AM
86White_T/A305
08-17-2015 12:16 AM
jackhammer
08-15-2015 10:04 PM
Quick Reply: Where to mount the blow off valve
