RMT Twin Turbo 350 using T3-45's?
Car: 1990 Iroc-Z
I was wondering if any of you have any suggestions, tips, or just see something that I don't. Playing around with the idea of RMT and doing it cheap I found that 2 T3-45's off of Ford Turbocoupes and Mustangs and Dodge's have around the same charecteristics (sp?) as a singe 60-1 that Squires supposedly uses in their RMT system. Would this work, doesn't have to be perfect, just wanna add some power to my stock TPI 350. Say 6psi-8psi. A have run the numbers the best i can and found that it seems like it should work quite well. P.S. these turbos, are sized smaller for the reason of the remote mount location, as is the 60-1. But I think i could rig that up for 1000 dollars or less for everything, plus it would be a fun project. Any info would be appreciated.
bjpotter
01-22-2019 12:27 PM
