Cast pistons OK with 10 lbs?
Car: 85 T/A
Engine: BBC
Transmission: glide w/brake
How much can you go with cast pistons, and what is the biggest killer of them? HP, cylinder pressure, or RPM?
Would like to use forged but not sure if they are necessary for what I am looking for. Single Turbo 350 around 350-400 hp.
thanks
thanks
1 Post
Car: 1992 B4C 1LE
the P1sc kit that people put on thier 3rd gens makes around 9 psi and peaks to 11-12. that is stock cast pistons setups. it is intercooled. the head gasket is usually the first to go too.
what kind of compressionare we talking about here?
I have seen some 142 blowers on GM replacement motors too.
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Detonation kills the pistons, not the boost!
Also, if the rings butt ends, that can pull the top of the piston off (so I've heard).
Car: 85 T/A
Engine: BBC
Hey guys,
It is a 1990 non roller 350 truck motor. Originally TBI, but now I am still up in the air with the fueling part. I would like to try injection, and as a matter of fact I have a slew of PCM's I went to the junkyard and got, but I don't have the tools to program or burn. My other option is the Megasquirt.
Anyways, the engine is the 90 TBI truck engine. I have it all apart right now, the stock compression ratio is 8.2:1 so the compression is right. I have a older set of 2.02/1.64 mildy ported heads at 72cc, the factory cam is tiny at around .380" lift. I think I will change the cam, not sure yet. If I put a set of 1.6 rockers on it, it puts the lift up around .420", but still not sure if that's gonna be enough.
I was wanting to run a non roller solid cam around .500" lift, cut on 112 or 114 LC, but still unsure about a good one to top off the combo.
Anyways, I am looking for a street friendly 400hp/400tq turbo engine that is "FUN" to drive. Getting tired of trying to drive 12:1 engines around alot.
Thanks for any info and advice.
Mike
Mike
1 Post
Car: 1992 B4C 1LE
sure
but I think a 10 pound piston is much too heavy for such a small engine. Heck you will have 80 lbs of piston by the time you are done
Car: 85 T/A
Engine: BBC
Originally posted by B4Ctom1
sure
sure
So the general consensus is cast pistons can handle 10lbs, and up to 13, given the timing and fueling is correct?
One more ?
Has anyone PERSONALLY ran a cast pistoned 350" SBC around 400 hp, (naturally aspirated or forced induction) in a street machine for 30K+ miles?
Looking for some personal experience on longevity and issues.
Thanks again guys,
Mike
1 Post
Car: 1992 B4C 1LE
I can tell you that if you replace that 8.2:1 compressiont TBI 350's 64cc heads with some 72cc units you won't have 8.2:1 anymore.
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
Mike I have an L98 with around 400hp...my car has about 65K on it and runs fine....I'm running 58cc AFR heads (10.1 comp???)...my car has no power adders...and the factory cast pistons....I've been told if your gonna get blown get the right engine pieces first....... BTW your pretty close to where I'm from!
350Z
350Z
Car: 85 T/A
Engine: BBC
Ok, I bought some 2256 F .040" over's. Thanks for the info guys, any advice on a good cam?
POS350Z, where are you at?
1 Post
Car: 1992 B4C 1LE
Originally posted by 83 Crossfire TA
The 1500 TBI engines were 9.1-9.3:1 and the HD (2500 and 3500) trucks got 8.9:1
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
My new setup uses a inverted dome piston, and a 64cc head. 9.3ish:1 compression.
-- Joe
1 Post
Car: 1992 B4C 1LE
if your TRW's died at 12 psi I would look elsewhere for a failing.
timing, a/f ratio, or not destroying quench with big chamber heads to reduce compression, or maybe some ring issues.
those piston's reputation speaks for itself in applications nastier than that which 12 psi boost can deliver.
Engine: LC9, LT1
"Blower pistons" have inverted domes to match the chamber, the ring sits lower away from the fire, and they're usually lighter.
The good thing about a 2256, which is why I always used them, was they are one of the cheaper forgings available, and the weight is similar to a stock cast piston, so you can get away with not balancing the engine.
-- Joe
1 Post
Car: 1992 B4C 1LE
it wasn't an attack, just seeing them in nasty applications with heavier boost or nitrous without failures is what I mean.
Then again it could have been a forging failure.
I have heard about some wierd things going on since federal mogul did their big change over.
Nothing I can substantiate, just heresay at this point. If this is the case then I suppose then there could be cig problems with running this piston with heavy boost.
when you say 12 psi, were you talking nominal or peak?
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Thanks again guys,
Mike
Thanks again guys,
Mike
The car ran 14.1 @98 mph at 3600+lb race weight before the boost, so it's probably near the 400 hp mark now.
Like everyone is saying, detonation is what kills them.. Before getting my tune "right", I broke some ring lands and rings..
So far, my cast pistons have held up to tons of 10psi blasts and a few 16psi blasts..
Stock short block with cast flat tops and 74cc heads..
Cheers,
Cheers,
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
