F1 R Upgrade
F1 R Upgrade
Hey guys whats the biggest s/c that can fit in our cars?Have a F1 now thinking of switching to an F1R or something to go with the 434 we are getting ready to put together.Thanks guys
I e mailed procharger earlier today and asked that question.Hopefully the will respond next week sometime.Another one of their F series the F1C I think use the same houseing as the F1.Will let you know what they say
Hey fireturd thanks for the thread.I have talk with Larry at ASSC a few times about a cog system he designed guess I will have to call him again.Anybody else running a big blower on their cars?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
/N.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Originally posted by gta324
I guess a regular F1 is "small" in this thread
I tend to use ATIs bracket with additional support...for a start....
/N.
/N.
Hey fellas just got off the phone with ATI they said the housing is slightly bigger but the internals are the same.Then they directed me to Larry at ASSC.Talked to him for a little while he makes the bracktry to do bigger blowers but to do so you have to run cogs give up a/c and p/s.This may not be worth all the effort.Have to think about this one for a little while.To see if it's worth giving up a/c.Gets HOT in the south
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
1 Post
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
ASSC
Did Larry also tell you that with the cogs they suggest you run an ATI balancer with a specially fab'd(bigger) hub assembly that requires a modified timing cover AND having your crank snout double cut to run 2 keyways?
They suggest this because otherwise, the balancers have a tendency to have a very short life.
Problem doesn't exist with the 12 rib system.
Things may have changed, but at least that was the topic of one of my last conversations with Larry.
Hey thanks for the reply.Yes I had a long conversation with Larry.He told me about the ATI bbc hub and running cogs.Right now he's running a F1 on his car.Even told me he could save me some money if I went with a F1R he would set it up with ATI since he is a dealer I can just send them my head unit they make the change over to F1R.Still thinking about it right now will make finale decision when the time comes.Need to finish motor first
dbrochard
09-25-2015 04:56 PM
