anyone has a ati pro charger???
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys i was wondering if any of you have installed a pro charger on a tbi motor? ill be getting the kit soon, it involves parts from the tpi application and the truck tbi parts, in conclusion a complete kit capable of 7psi. does anyone has pixz of this setup???
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Is the supercharger going to work on the TBI. The way blower work is the faster the air gets into the motor the faster it is going to get out. Which means the faster the car is going to go. The problem with TBI is there is only too little openings on the intake so this will restrict the airflow. At least that's what I think but if they are selling this kit for a TBI than I'm sure it will work.
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
https://www.thirdgen.org/techbb2/sho...hreadid=113322
https://www.thirdgen.org/techbb2/sho...hreadid=126925
https://www.thirdgen.org/techbb2/sho...hreadid=121859
https://www.thirdgen.org/techbb2/sho...threadid=36995
Some are cover the same pics but there's still posts to read.
Car: 89 Camaro RS
Engine: 5.0 tbi
yes they do make a kit for the tbi trucks but the only diffrence is that i will need the blower bracket and plumbing from a tpi application.everything else is a direct fit and capable of producing 7 psi with no tuning problems but i will bring it up to like 9 psi for more power.
