Solution to P1SC Pulley Wobble!!
Old 12-08-2004 | 09:18 PM
AC's Avatar
AC
Car: Used to drive a camaro
Well, I haven't had it machined yet (still waiting for quotes to come back) but did this: used a stock TPI serp crank pulley, procharger alum spacer and 8" procharger crank pulley. Put the assembly together as it would be on an engine and started measuring and designing in UG (very sweet CAD package) at work in my free time. I'm currently working on a FEA to determine the strength of the unit in either steel or aircraft grade aluminum. Here are some renderings of what it would look like.
Old 12-08-2004 | 09:23 PM
AC's Avatar
AC
Image 2
A couple more
Old 12-08-2004 | 09:24 PM
AC's Avatar
AC
Image 3
Final image
Old 12-08-2004 | 10:07 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
very nice! I'd be curious about what it would cost to have made up?
Old 12-10-2004 | 03:04 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Looks pretty good!!! Think you could get a quote with a extra 4 ribs added onto that design
Old 12-11-2004 | 02:50 AM
83 Crossfire TA's Avatar
Looks cool… but steel and aluminum would have different design constraints.
I’ve actually gotten away with using existing steel pulleys and welding them together with spacers/plates that fit in between things… it worked out much better then I expected as long as I figured out some way to fixture it like I wanted it.
Old 12-13-2004 | 11:31 AM
Steve89GTA's Avatar
Is this a common problem with ATI's kit? WTF, for that much money?
Old 12-13-2004 | 02:26 PM
AC's Avatar
AC
I don't think the pulley design is better than say the Vortech which is a pulley that inserts into the stock one. ATI's is a 3 piece, stock crank pulley, alum spacer than the blower crank pulley. Trying to align (3) objects rotation axis can be d*mn near impossible sometimes. I battled with it for better part of 2 months. Now I've designed a one piece unit.
Old 12-18-2004 | 08:26 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Vortech uses two stock pullys and a spacer. Sounds like its identical to the ATI setup, except.. I've never had aproblem with it..
-- Joe
Falcon50
08-22-2020 04:26 PM
Pac J
05-17-2020 11:44 AM
bigjay89gta
10-15-2015 09:04 AM
jaridjohn
10-05-2015 08:01 AM
anesthes
09-30-2015 08:48 AM
