DIY Vortech Rebuild!
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
If your vortech is in need of bearings, and you don't want to pay he mafia (vortech) $600.00 for a rebuild you can order the following and do it yourself:
2 Nachi ball bearings nac-6003 (must be speed rated, 55,000 rpm)
2 SKF Ball Bearings 6205/C3
1 Chicago rawhide seal SC/R-6248
1 Transcom seal TCM-25x40x7tc
1 Chicago Rawhide Speedi sleeve C/R-99062
If you contact the folks at supercharger rebuilds (sales@superchargerrebuilds.com)
They quoted me the following:
"I can get you everything for $142.04 (4 SKF bearings, 3 CR seals). That is
with SKF bearings for all bearings; they are higher quality and same RPM
rating than the Nachi.
Thanks, let me know,
Todd"
-- Joe
Todd"
-- Joe
Car: 89 vet
Engine: v8
Transmission: Automatic
Those are good prices! When I rebuild mine the bearings alone ran me $189.00. I did order max duty instead of the Standard bearings. Also be advised you will need a press for half the job since one set of bearing is pressed on.
ED89
ED89
Engine: LC9, LT1
ED89
ED89
-- Joe
1 Post
Car: 1992 B4C 1LE
joe, if you rebuild it take some pictures, let us see what the mafia thinks $600 is worth
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Pictures from when I rebuilt mine ... but I did not get the right bearings for the output shaft and I reused the putput seal.
http://jobyteknik.homeip.net/corvett...arger_rebuild/
SKF-6205-ETN9 <- this is the one I used
SKF-6205-2Z
SKF-6205-2Z
Car: 1984 Corvette
Engine: Turbo 350
Re: DIY Vortech Rebuild!
-- Joe
-- Joe
Engine: LC9, LT1
Re: Re: DIY Vortech Rebuild!
Originally posted by JoBy
Do you know the SKF bearing number for the smaller berings?
You used a speedysleave when you did yours right??
-- Joe
Car: 1984 Corvette
Engine: Turbo 350
Re: Re: Re: DIY Vortech Rebuild!
Yep, I'll dig through my email. Parts should be here in a few days.
-- Joe
-- Joe
Engine: LC9, LT1
Yeah. that was included in my original partrs list. Gives the bearing a true surface to run over.. Hrmm..
-- Joe
-- Joe
Engine: LC9, LT1
Originally posted by CrazyHawaiian
What happened to cause the rebuild? Sorry I'm just curious. Did it seize up or something?
Either way, I wanted some bearings rated for 55,000rpm. My case is an A-TRIM, but an S-trim impeller and volute.
-- Joe
Car: 89 vet
Engine: v8
ed89
350, atrim, bad, bearing, instructions, kit, l480e, loud, rebuild, rebuilding, rebuilt, supercharger, superchargers, tci, turbo, vortech
