vacuum location for fmu
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
Could someone tell me if the same vacuum line that is used for the boost gauge can be tapped into for the fmu? Or should it have it's own vacuum point? Thanks
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
The FMU can source vacuum/boost from the same line running to your gauge. The FMU doesn't need a large feed to it- infact, most FMUs have a restrictor in the sense line. Just make sure the source is after the TB so it reads actual manifold pressure, be it positive (boost) or negative (vacuum).
86CamaroDan
09-29-2015 10:08 PM
