305 4bbl SUPERCHARGER?
Car: 84 Z28
Engine: 305 HO
hey guys...i own an 86 camaro w/ a 305 4bbl an was trying to find out if an company that made supercharger.....if so...please help me out....i'm a newbie to the muscle scene since i just sold my integra gsr for the camaro...thanx alot....
-hopeless
-hopeless
Car: Black 1984 Mazda Rx7
Engine: SBC
Transmission: WC T-5
Axle/Gears: 4.10 LSD
Welcome to the.......better side.....or however you wanna call it, I dont know where to start, how bout how much power are you looking for? And How Much Money Do You Want To Spend, We'll Start There ok =D
~Chris
~Chris
Car: 84 Z28
Engine: 305 HO
well.....i'm only 16 so i'm limited to cash right now...i want to get as much HP as i can without having to go buy a 350ci...i would like to buy one right now but i dont have the money. pretty much i just want somethin streetworthy...i know the LG6 isnt the best motor to build up on...but i guess i gotta work with what i have.i'm already planning on a B&M shift improver kit...a chip an 3.73's.....all i ever knew was import performance so the whole "muscle" scene is too confusing...
Car: 1989 C4
Axle/Gears: 307
I dont know how well the factory CC carb and ECM would handle having a super charger slap'd into the mix. I dont think it would quite cut it. The easyest way to gain power with less hassle would be te 144 Weiand blower, but theres always hidden cost with that.
Car: 84 Z28
Engine: 305 HO
yea...i need to buy a new carb anyway b/c its been rebuilt 3 times an is startin to screw up....but i just dont have the cash to put down 600 for a performance carb...i'm gonna get a summit remanufactured one for about 300...b/c i still need to get it up to inspection.....another Q....how do i know if my camaro is a "G" or an "H"....
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I'm 17 and I also have an '86 305 4bbl. An LG4. I've looked into the whole thing and I have decided the best way to go (for me) is to either rebuild my 305 and put a s/c on it or just get a rebuilt 350. And I dont think I need to tell you which will be more reliable or cheaper. And since I'd only be putting like 8-10 lbs into it anyway, I think a n/a 350 is better for me.
If I thought my 305 could handle a s/c right now then that's what I'd do, but I seriously dont.
And 600 for a carb? Even 300 is a little high. You need to look around harder or get to know certain people lol. Try ebay. ebay has everything. Including cheap carbs.
Car: Camaro
Engine: 355c.i.
Transmission: th350
while it wouldnt be the greatest thing in the world, you could even get just a 350 shortblock and put on all the 305 stuff, and it would pass emissions just fine assuming its not a ****ty engine. that would hold you off until you could get better heads/cam etc. but if you have enough to do a supercharger you could easily get a good performing 350. go to a swapmeet or ebay or whatever get a used aftermarket intake and carbeurator, rebuild the carb. get a powerband from around idle -5500rpm (maybe 6500...but whatev). I see in the newspaper all the time where they have complete 350 long blocks for 950 bucks. new and all that jazz, its just a basic 230hp ish 350. then while its out swap in a mild cam and you got a great performer for less then 2k. but if emissions are a big concern for you just get the 350 long block and new cam and throw on the 305 intake. temporary but it works.
a chip
an 3.73's.....
for what you would spend on a S/C you can drop about the same a get a Jasper 350 from a 1986 caprice. I have one in my camaro for 3K definetly faster than the 305 HO and with the 3.73 and 5 spd stick it puts a hurting on my 87 IROC with the 350. Also it's only sitting at about 8.3:1 compression so you can always boost it later with a 144. (I'm working on the Buying a Blower part right now). 2 things I recommend, Buy a nice 2 plane manifold like an Edelbrock and get a decent set of headers.
Car: 84 Z28
Engine: 305 HO
WOW...thanx for all the input from everyone...i'm soo glad i found this website....i would have been so lost without it...thanx again....you are all car "life" savers...thanx again
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
For what it's worth, I found a guy locally who will rebuild my CC carb for about $150. If you can find the same, you'll save more money than you thought.
Hotrodboba400
12-10-2019 07:07 PM
1051, 144, 1987, 305, 4bbl, blower, camaro, carbureted, chevy, compression, ho, street, supercharged, supercharger
