supercharger for a 86 tpi 305 trans am
well first of all i did a days worth of searching and came up with nothing.it was all 88 and up stuff. I was wondering if any one knew who makes a supercharger kit for my car.
86 transam
freshly rebuilt t.p.i. 305
built 700-r4
thanks for any help
86 transam
built 700-r4
thanks for any help
nope, no one makes anything for the v belts anymore. You just have to convert to serpentine with all the serpentine accessories and the water pump as well, and then any of those 88 and up superchargers will bolt right on.
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
You need the pass side serp bracket/bolts, if you run AC you need the serp compressor>>>if not you need the ac delete pully, you need the waterpump and a later year alternator... You also need the PS pump pully....the pump you can reuse>>the pully has to be removed and a new one added... I think You need the crank pully as well ...
There are some little things as well such as fuel lines.... They wont work...so from the rail I used Accel Fuel rail -6 kit...and then some TPIS saginaw to -6 adaptors...then ran -6 line from the fuel rails to the hard metal line.... Looked much cleaner and cheaper/easier than buying the later year hard lines...
It all sounds more difficult than it actually is... LOL
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I've got the "later year" hard lines sitting on my shelf, as well as some serp brackets, maybe a ps pump too.. If your interested.
-- Joe
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
305, 86, 86tpi, 87, camaro, centrifugal, charged, charger, chevy, super, supercharger, superchargerfor, tpi, tpi305, trans, tubo, turbosupercharger
