What Is the Biggest turbo?
Car: 1985 Pontiac Friebird Trans Am 305 TPI Recaro
I've seen the T-76 turbo and its pretty big, is there any other turbos that are bigger?
The pic is a T-70
The pic is a T-70
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Drewace
Wow thats huge, Ok whats the largest turbo that would fit into a third gen?
- how big of a motor can you shove in a thirdgen?
- how much do you want to cut?
- any objection to having a turbo waaaay oversize for the motor?
im suprised no one posted the pic of the guy standing next to the 5' turbo... (yes five foot)
I'm just looking for a large turbo that could run off say a 350 sbc and push as much hp as possible so i could run with the TT guys with a single turbo. I found Holset has some huge turbos for diesel engines and they could probably be used on a 350
Car: 91 Camaro Vert
anyturbo could work since it has to be fabbed in anyway....
you just need a appropriate one for your engine.
I see that people are actually collecting some of the pictures that I've posted...
in an f-body... I always thougth that this one was fairly good sized:
Car: 1992 B4C 1LE
Car: 1992 B4C 1LE
same idea but not as big a turbo (really gives you an impression how much room you could make if you just don't care):
was the exhaust too big? how much boost did it make?
did it blow to smithereens?
is that a 3.8 or a 4.3?
Originally posted by B4Ctom1
I want to know more about this car, how did it do?
To be honest, I don't know that much about the setup, though I'm pretty certain I got the original link from this board, maybe the owner or someone who knows about it will turn up (search the archives?)…
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
