how big of turbo do i need?
Car: 1986 IROC-Z Camaro
Engine: 305 tpi
Sorry for asking this but i searched and found nothing. How big of turbo do i need to make roughly 600 hp on a 383? is a T66 big enough, or t78. again i know nothing about turbos other than than the very basics so any info would be greatly appreciated.
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
The 66 should be enough as long as were talking crankshaft hp, I was making about 650 at the crank last year with a TE64-1 before I ran out of fuel. Looking for around 700 this year with larger injectors, at that point I think I'd be at or real close to the limits of the turbo.
That said, I think a 78 would be overkill for a 600hp motor. Even if you wanted to go a little big I wouldnt go larger than a 70 which has been making 850hp in the Buick TSM classes.
HTH,
Steve
HTH,
Steve
redformula88
10-14-2015 06:08 PM
