lt1 intake vs. stealth ram for fi?
this is for my monte carlo but what are the pros/cons over using a stealth ram vs. a converted LT1 intake for a turbocharged 350 running between 15 and 20psi?
1 Post
Car: 92 Z28
Engine: Boosted LSX
Personal Preferance is what it comes down to.
The Only Con with the LT1 is I didnt like the damm remote T state housing so I got rid of mine befor I even fired up the motor.
Then Again I got rid of my HSR I had also.
So what are you going to run now, TPl383?
As far as under boost… your boost will have a much greater effect on power production then your intake choice. Choose what you like and go with that. Personally, I think that the stealth ram looks hokey, and the LT1 looks rigged by the time you get all the plumbing done to it. I mostly like how the TPI looks but I think it's a piece of crap and a hassle to work on, seems like you have to stop everything and spend half a day taking half of it apart to change anything in the fuel system.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
-- Joe
1 Post
Car: 92 Z28
Engine: Boosted LSX
Then again I could sell all that crap and buy a FIRST setup. Seein badSS's thread That looks like a nice setup.
Engine: LC9, LT1
I'm trying to fab a ls1 75mm tb right now to a TPI plenum. I have ported slp injectors and edel base, but I'm gonna run a set of true siamesed stockers that bandit'91 made.
Just gotta open 'em up a little more and port 'em.
-- Joe
-- Joe
Originally posted by anesthes
Hrmm.. It normally takes less than 10 minutes with the air ratchet to take the runnes/plenum off to get access to the fuel rails. I'm using allen head bolts though, not the torx and an allan swivel (ball end) driver.
Originally posted by TPl383
I havent desided on that yet... I sold my superram also. Im wishing I would have keep that now. But since Im gona run them Twins I got off you and I really dont have a major HP goal. Im thinking a simeesed edelb.base Sell the SLP runners and get some AS&M runners. and a 52MM TB. 12psi and I have no clue what Cam or Injectors yet.
What are you gaining?
1 Post
Car: 92 Z28
Engine: Boosted LSX
I know that appearances are fairly important on your car… It's too bad that there isn't really a killer looking intake setup for these. I like what the TPI looks like with polished runners. I also liked that first gen that was running around a while back with a TPI plenum modified too work on a tunnel ram base (I know, basically the same idea as the SR, but it looked SOOO MUCH BETTER).
And I deff. Agree on the Plenum moded for a TunnerRam setup.
Kinda Like the FireFox???
Ive thought of getting creative and buyn another HSR and just ditching the stock plenum and making one.
Engine: LC9, LT1
Why would you do that? You'll end up with the flow of a 52mm throttle body, tip in problems without a major reprogramming, linkage problems (I suppose that you could grind the linkage off of the stock TPI TB and weld it on) and a major PITA to adapt it.
Anyway, the 75mm is equal to a twin 53.. more than my twin 48.
And instead of splitting it off in the discharge tube, then the airfoil into two holes, it can be almost a straight 3" shot into the plenum..
-- Joe
1 Post
Car: 92 Z28
Engine: Boosted LSX
Now this is the one that I was looking for
ya id deff like to know what They used on the FireFox and see better pic's
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
That Looks like the Street and Performance one..
On a side note, I just bought a Stealth Ram..
Going to stick the crossram on a another 305 and make a single TBI plate and drop it into my F100. BW
1 Post
Car: 92 Z28
Engine: Boosted LSX
not mine. It was coustom made for a member on the corvette forums for his 532bb with a prochareger in a 91vette.
The post with the owner of the car.
http://forums.corvetteforum.com/zerothread?id=718301
Pics of the process It took to make it.
http://www.hotrodsolutions.net/EFI4.html
Cost was $3100bucks I belive Last post one the 1st page.
tons more pic's of the motor in the post he made on the cf forum.
BW,
You have the HSr on yet? any pic's?
BW,
OK, mind you I know that I'm being a PITA and overly critical… but I always thought that intake was a great example of having too many cool tools and some skills (I say "some" since a lot of that could have been done better/faster, and after spending over $3K to have it made the owner still had to spend something like another $300 it flat enough to seal on the engine) and to little knowledge.
For his roughly $3.5K he probably has the same A/F distribution issues that you get with an LT1 but much worse. I'll bet that his rear cylinders are running much leaner then the front. Runners that are too short. Air actually has to reverse direction to get into the front runners, plenum volume/TB that are too small for the 500and some CI that it's on... Not to mention I think the top welds on the plenum are ugly.
I understand that all of this probably couldn't have been fixed perfectly and still fit well in the 'vette, but it could have been much better. I'd bet that Hogan's would have made something that at least didn't look like a gift wrapped elephant.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Hotrodboba400
12-10-2019 07:07 PM
Stangski09
11-14-2015 01:27 PM
New2Chevy
09-28-2015 12:35 AM
