turn manifold upside down for turbo?
Is there any reason why a manifold could not be turned upside down for adding a trubo? I have a couple of manifolds from some 327 trucks that are shaped in a "M" they look like they would work upside down and then run a pipe from the manifold to the turbo
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Car: 82 Trans am
Engine: Twin turbo 350
This is exactly what im doing. You will need to find some manifolds that have both exits at the rear (unlike l98 manifolds, which the driver side exits between cylinders 5 and 7).
Take a look at manifolds from a late 80s/early 90s fullsize van (with a 350 obviously). They seem like they would flow decently and are almost a perfect fit.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Just modifly some L98's like this.
BEFOR ceramic coating
![](http://s89724942.onlinehome.us/images/other3rdgens/TURBOCARS/KentonHurst89IROC/Turbomanifolds.jpg)
AFTER
![](http://s89724942.onlinehome.us/images/coatedparts/CeramicCoatings/Turbo%20Manifolds.jpg)
NOT MY SETUP , I just coated em for him.but its a Forum members.
http://s89724942.onlinehome.us/image...onHurst89IROC/
AFTER
Car: 89 Formula
Engine: 355
Wonder if my rams horns off my vette would work if I chopped them down at the exit. Pretty much look like this:
![](http://www.cadvision.com/blanchas/54pontiac/2exh1.jpg)
Car: 82 Trans am
Unlikely.
Those l98's have the "log" positioned above the exhaust ports. Your rams horns manifolds would be flipped to extend a few inches below the ports. Not certain, but its a good bet that it would interfere with the spark plugs.
My criteria for choosing an oem manifold were:
1. downturned, rear exit
2. something that extended down below the spark plugs, so there was no clearance when it was flipped.
my only concern was that the manifold would hit the valve cover, but now that i test-fitted them to the car, i dont think theres any way for that to happen
Street Lethal
04-30-2019 12:14 PM
transaero
08-31-2015 01:14 AM
86IROC112
08-17-2015 02:00 PM
