Which turbo for my friends car
Car: 1991 Camaro Z28
I know I'm not a normal on the Power Adder forum, but I've seen alot of good turbo posts lately.
Here's the deal, a friend of mine is about to switch from blower to turbo, but he really doesn't know awhole lot about turbos, so what are some things he should research and what size turbo should be run.
His engine as is:
406 Small Block (Dart block)
Forged 6" rods
JE Pistons -28cc dish around 8.4 comrpession
AFR 210s minor porting to flow about 15 cfm over stock AFR 210s
Accel Gen 7 with 90lb injectors
Cam is around .650 lift, 250-260 or so duration range.
Procharger D1R at around 18lbs of boost.
It recently ran a 9.16 at 148 but he's unhappy and thinks he can benefit from a turbo.
There is a possiblity that he may switch to 18 degree heads, but at the moment, he's going to keep the AFRs and try just a turbo swap. What would you recommend for him?
His engine as is:
Forged 6" rods
I've had both, they certainly are different in terms of average power. The turbo will flat out whoop any centrifigual in on the mid rpm torque. Can he fabricate? Otherwise he'll be looking for a kit or someone to do custom headers. They can be done in stainless or lower cost solutions like weld els work well too.
The plumbing will need to be custom aswell.
Turbo selection depends on how much power he wants , whether he's more comfortable plumbing twins or a single, intercooler design and drivetrain.
Don't get me wrong, Procharger's make great power but, the proper turbo is tough to beat. Feel free to email me for any specifics.
Originally posted by biggtime
Does he want to sell the d-1???
He plans to sell at the beginning of the new year I believe. I think he wants to sell everything, blower, brackets, intercooler, all piping and so fourth. If your interested, welcome to call him at 478-256-8732 ask for Brian.
I'll send him a link to this thread sometime and he may want to contact you. He's still up in the air on his decisions. One guy is telling him 106mm other is 98mm.
BMR suspension products is doing a turbo build up.. i forget the specifics on the motor, but its a small block (rocket block) with SB2 heads and the spider intake used in nascar, they are using a 96mm turbo and plan on making 1300HP and running mid 8's... maybe check that out... and proturbokits.com sells 88-106mm turbo's, aswell as the air to water intercoolers to support upto 2500 HP... but a COMPLETE custom kit is like $10,000
Terrell351
06-13-2021 01:13 PM
Linson
08-21-2015 02:12 PM
