What belt size for D-1SC 3.40" Pulley?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I will be going from a 3.90" pulley to a 3.40" pulley on my D-1SC.
I was told by ATI that the same belt would work (080645), but I see different experiences from posts on this site.
Anyone with this setup please give me your experiences with your belt size.
I figure that I will get the next size smaller and keep it on hand just in case.
Thanks!
Thanks!
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: 1991 Conv. TA
Anyone??????
I have found past posts that the 080644 is still too long and the 080640 is too short (1/4").
If I get the 080640, can the belt be stretched 1/4"????
Thanks.
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Thanks.
Car: 1991 Conv. TA
I have been doing some research.
When I originally put on my D-1SC with a 3.90" pulley the supplied Gates 080645 was very difficult to get on. I finally got it on by unbolting the SC and much effort rebolting it. The belt walked off when I started the engine and got ruined. I bought a NAPA 080645 and it went on in 20 minutes! I am still using this belt.
So I got some info on Gates and NAPA belt lengths to see what differences there might be between the manufacturers. Here is what I found:
NAPA:
080645: Length= 65.5"
080644: Length= 65"
080635: Length= 64.50"
Gates:
080645: Length= 65.25"
080644: Length= 65"
080635: Length= 64.25"
The difference in the affected pulley circumference between the 3.90" and 3.40" pulley is 0.785" (measured as 1/2 circumference which is touching the belts).
I was using a NAPA 080645 at 65.5" for the 3.90" pulley so the belt size I will need for the 3.40" pulley is 64.715".
The closest belt size is the NAPA 080635 at 64.50". Since this is less than 1/4" too small it is comprable to the Gates size that was sent with the 3.90" pulley which was also too small. Therefore, it should fit with the same difficulty as I mentioned above.![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
Does this sound right????
Thanks!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
NAPA:
080644: Length= 65"
Gates:
080644: Length= 65"
Thanks!
Car: 1991 Conv. TA
So am I the only F-Body on the list with the Procharger 3.40" pulley??? ![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Like Willie just said in a recent post, "Where no man has gone before."
Need some input here!![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
Car: 1991 Conv. TA
Thanks for the reply Biggtime.
I am planning on using the shorter belt. Dorian at ATI suggests trying to get it on as the belt will stretch over time anyway.
He did also say that he could send me different size idler pulleys if necessary.
I plan on doing this work over the Christmas holidays so we will see what happens.
1 Post
Car: 1992 B4C 1LE
there is a sticky at the top of power adder here showing a twin intercooler setup
Car: 1991 Conv. TA
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Thanks man, did you put your front fender ground effects back on? If so, did you have to mod them to clear the intercoolers and/or supply air to the intercoolers?
Car: 1991 Conv. TA
Yes. I did initially modify the front corner pieces. Looked pretty good and allowed the air to enter the intercoolers.
When I had my new hood painted and installed, I also got the front bumper and ground effects repainted.
While doing this work, the bodyman made the cut on the side ground effects even sleeker. He has worked on my cars for the last 5 years and is very maticulous.
I can send some photos later.
Car: 1991 Conv. TA
Just to finish off this thread.
The correct belt for the D-1SC with a 3.40" pulley is a NAPA 25080635: Length= 64.50".
I just installed mine with the help of my wife. I had to remove the driver's side top bolt, the two passenger side bolts and loosen the bottom driver's side bolt of the blower to get the belt onto the pulley. I then pulled the blower into place and she threaded and tightened the two larger bolts. I took it from there.
The belt rides on the pulleys just fine.
I took it out for a ride and was able to get 12# boost . Too much traffic to go all out. ATI expects the blower to produce 15# on my set up.
This will give me 460 FWHP. Not too bad for the little 305!![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
I plan on tuning the alky injection over the holidays to ensure that I am getting zero knock.
This is the end of my project. Hope others can get some help from my experience.
Happy holidays!
Happy holidays!
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
pics, pics, pics, (of front ground effects)
. I am going with the d-1 and twin hi flow's on the 92 bird.
Car: 1991 Conv. TA
Re: What belt size for D-1SC 3.40" Pulley?
I wasn't happy with the way the 3.40" pulley made the car run in cold weather.
It would cause the supercharger to vibrate badly.![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
So I went to a 3.70" pulley.
I am now going to try a 3.55" pulley afer all of these years!![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
I will advise of the outcome.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Nice to see your car is still working 7 years later lol
Where you getting this 3.55" pulley? didn't know procharger made one for our cars.
Car: 1991 Conv. TA
I just called ATI and asked what sizes were available for the D-1SC.
The 3.55" was the next size up from the 3.40".
The car popped in cold weather with the 3.40" so I stopped using it 7 years ago.![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Call em up and for a c-note they will send you one too!![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
Sean
Sean
Car: 89 GTA
I got the 12 rib setup might be why.
Good luck with the new pulley.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Yea the options are far less for the 12 rib vs the 6 and 8 rib setups.
Here is a great site that sells/lists all the pulley's procharger has available.
The offset is the one you need for the P/D/F series unit's on the Fbodies.
http://www.houseofboost.com/store/su...s/cat_162.html
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Hey guys - Sorry to bring this classic back up 2 months later and change course a little, but I thought I'd get some good "power adder" minds input.
Thanks for the pulley info link btw 3rd gen Will. Who is the best priced vendor these days for ordering procharger pulleys?
I have purchased from D'agostino Racing and direct from ProCharger. Always seems to be around $80-$90.
In the past 2 years I have changed pulleys from 4" to 3.7" and recently had a friend fabricate a pretty trick extra bracket to help reduce the main bracket flex issue I was having to reduce slippage.
After all that I'm still only getting 6psi with a P1SC kit that's only a couple years old. This is on my aftermarket TPI|Trick Flow headed|Comp cam'd, but still stock short block, GTA 350.
I was planning to drop down to a 3.4" pulley next year, but it seems to me I should already be closer to 10psi at this point, which is my goal. Any thoughts? Thanks. ..
I haven't purchased any pulley's so your guess is as good as mine as far as cheapes place. I have seen quite a few pulleys go for around 50-60 on ebay new and used though.
What PSI @ RPM are your pulley's set up for? w/ better flowing heads/cam it's not uncommon to be a couple PSI below what procharger says. Their #'s are typically for stock setup's, if you don't have boost leaks and are making less PSI than you expect, you would actually be making more power because your engine is flowing the air through VS it stacking up in the intake. You are actually moving more CFM of air through the engine which is what makes power.
Car: 89 GTA
Car: '89 GTA
Thanks for the reply. I'm aware of how the supercharger works and the expectations of a modified engine vs stock.
The ATI advertised ratings for P1SC was I think 9/12psi on a stock motor (w/2-core intercooler), but that is with the 4.25 pulley that it came with.
I've changed pulleys twice, 4.25->4->3.7 thinking that 5 tenths of pulley size drop would make up for ~5psi worth considering my setup is far from stock.
I do have the 3-core intercooler btw. No major boost leaks to note. We did notice the surge valve did leak some and capped it during testing which showed minor gain. Going with a BOV shortly.
Seems to me that there are plenty of streetable head/cammed ProCharged cars running ~10+ psi. My setup can't be that efficient at moving air can it? haha.
Tony - Yes, your car is a similar example I've seen over the years to compare, but yes it's the D1SC instead so it's hard to say. I think I'm missing at least 2 more psi somewhere at least.
Car: '89 GTA
Forgot to mention I'm still using the FMU/24lb injectors, but moving towards 42lbs, a 749 ecm swap and SD/2-bar setup this winter.
Car: 89 GTA
You might want to consider using EBL since you haven't already converted over, looks like a great way to go plus you get to keep some of your emissions systems working. I find the 749 system kind of a pain in the *** to work with and more setup for the V6 but with the code 59 it's still workable. Also you might want to go bigger on your injectors the FMS 42's I had before never really idled very well, my siemen 60Ibs work much better plus I have room to grow.
Car: '89 GTA
That's funny, you just posted this while I was reading the dynamicefi site on the EBL. I've not kept up on what's out there and have already purchased everything I need for the 749 swap and 42's however, doh!
I did buy some SVO green tops, not from FMS though. I have a very experienced tuner helping me with that aspect whom has had amazing results with this swap on his '87 Corvette. We were never able to really perfect the idle and cold start issues on my current MAF setup, so I hope this is a step in the right direction. Not to mention ever being able to tune for boost. Unfortunately all this probably won't do much power wise I don't think, just getting rid of the band-aid FMU. It's been awhile since I calc'd, but I thought 42's was leaving me a little room to grow already.
Procharger rates the P1sc at 1200cfm 30 psi and the D1 at 1400cfm and 32psi.
With a P1SC unit, assuming you have an 8" crank pulley with a 4.25 pulley you would see around 7.5 psi @5500 rpm and 9.4 psi at 6000. going to a 3.7 pulley would get you 10.5 @ 5500 rpm nearly 13spi at 6000, all of these figures are approx. for a stock TPI engine.
For reference 8" crank 4.25" blower at 6k rpm, A P1 puts out 9.4 psi vs the D1 should make 12.1 psi All things being the same except using a 3.7 blower pulley The P1 should make 12.9 and the D1 16.1
Car: '89 GTA
Thanks, good reference points there.
So that being said, if ~13psi@6000 on stock TPI with a 3.7", you would think my peak 6psi@ roughly 5500-6000 is under par, no? I think it should be closer to 8 at least! I just hate to throw yet another pulley, the 3.4", if there is something else I'm overlooking. When I last spoke with ProCharger they said much like anyone else would; check for bracket flex/slippage/leaks, which I think we've covered.
Car: '89 GTA
Keep me posted if you guys discover where that 7psi went. I got back maybe 1psi just by capping the surge valve during testing. Not sure where else to look for a few more psi other than getting a smaller pulley and maybe having it coated to reduce higher rpm slipping possibly.
Car: '89 GTA
Yeah I've read and talked to the Reichard folks before. They claim as long as you're aligned properly, it won't trash the belt.
I got some good info/feedback about Carbinite Racing and the coating they add to pulleys.
Not sure what else to do at this point. It would have to be a noticeable boost leak I'd think to be losing 3+psi
Car: 89 GTA
Pic of my sand blasted pulley to give you a idea, be lot cheaper then getting it coated or messing around with a new pulley.
![Name: IMG_0202.jpg
Size: 78.6 KB](https://www.thirdgen.org/forums/attachments/power-adders/403937d1501447213-what-belt-size-d-img_0202.jpg)
Car: '89 GTA
Well with a smaller pulley you just winding the blower up even more, which you shouldn't have to do.
Nice ideas and visuals. Gives me something to think about.
Tony - Any measurable difference noted with that coating? Your earlier post said you are using 3.7". Is this coated one a separate 3.4" that you have layin' around now? Doubt you'd go backwards. Wishful thinking, heh.
There's also a guy on eBay that constantly has auctions for doing what Reichard does to pulleys for a lot less with the slots and he puts holes in them too for supposed weight savings. I prefer to try the coating route first, sounds safer.
Car: 89 GTA
Yes is a spare pulley I was using when I was running stock heads and cam making 16psi. I was having lot of problems with belt slip then after blasting it down to the bare metal I found it keeped the boost at a steady repeatable level.
