looking for pic of drivers side downpipe routing
anyone have pics of a tt setup specifically where the drivers side downpipe is routed and also the diameter pipe they used for it. Is it possible to use 3"
thanks
thanks
Supporter/Moderator
The drivers side turbo in my case is above the #1 sparkplug. I've got the drivers side basically exiting rearwards, and it turns down fairly quickly. The downpipe then takes a turn across the bottom of the engine where the factory Y pipe used to go, and then Y's together with the pass side on the pass side of the engine, in front of the cat. I've got 2.5" dia downpipes for now, but I have seen 3", and will be making my next set from 3" dia, and plan on running it as true 3" dual setup, or Y-ing the two sides to a 4" dia dump pipe.
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
