Eaton M90 porting pics
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Since the Malibu is down for a new engine, I thought that I would port the blower cases.
Inlet has been opened up 5/16th inch and radiused inside. Outlet has been opened up 3/8th inch and bosses removed.
Inlet before/after.
Inlet before/after.
Nice porting work, looks good. What kind of gains do you expect to see with the porting. I know you have the twin blowers but i havent followed your car that close.
So here goes
What's the reason behind opening them up? More flow? more boost? or both
So here goes
Car: 84 SVO
Transmission: WCT5
So here goes
So here goes
Both...
Plus switching to 10% overdrive pulleys for even more fun.
BW
Car: 1992 B4C 1LE
dude I am soo excited for you I soo wanna see what this will do
Car: 84 SVO
Transmission: WCT5
Originally posted by rooster433
You ought to work out putting two throttle bodys before the blower then blow it straight into the manifold.
Unless you like 90 decible's...
I'm still impressed with how quiet mine is
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
so or you porting them out as you see it, going off directions from a book/website, getting help from silverback, or what??
just curious..
btw, this may sound strange, but what if you mounted them backwards down low ( idonno if you have the room)..
if they were low and forward you could run them directly into a intercooler, and then into the TB.... plus nice cold intake air is right there....
just curious..
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
That's a huge amount of material you have removed there. What did you use for the job, a die grinder?
I like the originality of your set-up. Looks good.
Robert
Robert
Originally posted by SATURN5
I've got something up my sleeve... just not quite ready for prime time. BW
Actually, I kinda doubt it... I think you've taken a more high tech aproach...
WRT to ideas... I think I did give him some clue what we did, but couldn't really supply pictures or anything of it. As far as what I'm seeing there was some improvement past roughly where that blower is at now by just taking more time radiusing the inside of the inlet...
Car: 84 SVO
Transmission: WCT5
I'm going to try and do that, but I have already popped thru the case so there isn't much left to work with. A little JB weld will fix the present holes, (no biggie as there isnt any boost there).
Rooster... yeah twin LS1 TB's ahead of the blowers.. and I may ditch the intercoolers.. haven't decided yet.
BW
BW
Car: 84 SVO
Transmission: WCT5
Originally posted by sleepybu
i think there good for 14000 to 16000rpm
83 Crossfire TA and bro have spun theirs to 18,000 and it seems to be holding up just fine.
With a 10% overdrive pulley I'll have a 2.64 to 1 ratio..
Shifting at 6800 spins the M90's to just under 18,000.
Vroom....
Block is a 3700010 4 bolt.
Crank is a 283 forged.
Rods are Carrillo 6" with Carr bolts.
Pistons are TRW 2441 .030.
The rest is under wraps...
I've seen a couple of cases that have had the ribbed areas in the back welded in or filled with epoxy (industrial JBweld works great, same stuff as the normal stuff but comes in bigger containers).
Different series cases are definitely different castings, with different webbing layouts and a different shape inside. I took a look at the one on the LTD today and noticed that the ribbing on it isn’t nearly as deep as what I’m seeing in your pictures and the intake mounting pad appears to be a little bigger.
And yea, we are spinning it to over 18K without any issues. You'll have problems with rotors expanding too much from the heat and contacting before the bearings go. FWIW, these things get more efficient as you spin them harder.
Car: 84 SVO
Transmission: WCT5
I wonder if putting a ceramic coating on the inside would have any benefits.. May have to check that out.
I noticed that Mike uses some butterfly bypasses between his TB's and inlets.. I'm assuming these open to the atmosphere under vacuum? I ran BOV's between the outlets and TB to release boost under light cruise and closed throttle, but Mike's setup has me a bit puzzled.. BW
edit: I found the bypass info. The bypass connects the inlet to the outlet under vacuum.
If you look at the pics at the top, the inlet one. I have come thru between the rear bearings and the bolt holes for the inlet, on either side of the rib. Since it's behind the rotors, filling it with JB weld from the outside shouldn't be a problem, no boost to worry about.
dbrochard
10-03-2015 12:43 PM
mrestrictrplate
09-21-2015 11:24 AM
UltRoadWarrior9
09-02-2015 08:24 PM
