best size single turbo for my setup? help?
I have tried calling every turbo company I can find and they are all unreachable for one reason or another, I need to find out what the best single turbo is to put on my...
383 stroker
pro action heads 72cc 235intake runners 2.08 and 1.60 valves
flat top pistons
victor jr intake
holley 850dp purchased from ati and tested on a 900hp blowthru supercharged camaroc(it handled 15psi ok)
compression is 9.7-1
I dont want to run more then 1bar and i will be running 2 really good intercoolers
I just need to know what turbo to get or how to determine which to get. thanks
383 stroker
flat top pistons
victor jr intake
aorund $1000 to spend but I need the right turbo so whatever it takes maybe just not with all the fancy extras and i want around 800hp, I currently make around 350-375 and I cant run more then 1 bar so maybe I am looking at 700hp? I just need to get the right turbo on there and figure the max hp out later
Well, first some quick math… a 383 with 72cc chambers and flat top pistons with a reasonable quench distance will usually be around 10.2:1 compression. Did you actually cc stuff and get 9.7? Either way, I really doubt that any iron headed engine with 9.5:1 or higher compression is going to tolerate any real boost without running into detonation problems unless you’re running race gas all the time.
Second, assuming your hp #’s are correct, and assuming that you match the turbo well enough to be at 70% adiabatic efficiency and the intercooler is 75% efficient (both are at the higher end of things, more likely you won’t be quite that efficient) you’d have to run somewhere in the range of 23psig boost (after the intercooler, probably 2 or 3 psi more before) to see 800 hp. I don’t know what fuel you’d need to run to make that work with more then 9:1 compression, probably something along the lines of methanol or straight toluline (117octane).
If you ignore all that and still shoot for that hp on that engine, I’d be looking for something like a T66 or larger… probably a T72 or T76 which would be right in their sweet spots putting out that kind of airflow and boost pressure.
Well, that’s a bit more reasonable… I would predict that with aluminum heads and 9.7:1 you’ll probably be safe for about 6-8psig on good pump gas with a good tune… somewhere in the 480-520hp range… That puts you in a different world with the turbocharger sizing, it’s much less pressure for the airflow and will require a larger turbo to move the air. The smallest that looks like it will work for sure would be a T72, but a T70 might work…
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
1 BAR is what you are running now, 1 BAR equals 14.7 PSIA which is what the air pressure is at sea level, and other factors like humidity (I think the spec is 70%) and a couple other variables. So to run "1 BAR of pressure" is 0 PSI. 2 BAR, is 14.7 PSIG (Pounds per Square Inch Gauge), this is what you would see on the boost side of the boost gauge, and what I think you are refering to as "1 BAR".
Hey, I was just pointing it out since it seemed like you didn't know...
And as far as selecting the right turbo, it takes more than just asking a question on a BB, there are many variables to selecting a turbo, how the vehicle will be used, type of racing, efficiancy of the engine, daily driver/weekend warrior/infrequent driver, among a lot of variables....
I can't see how someone could sit there with the limited info and say "X" turbo will be right, since even some of the most experianced turbo engine builders out there will tell you, you probably won't find the right turbo the first time, but with enough calculations and research you can at least get it in the ball park.
Besides PSIG is just a measurement of restriction, which is why ported or higher flow intake tracts will through some variables off, and make "the perfect turbo" seem not so perfect, since too many times people look for a certain number on the gauge, instead of proper amount of air flow from the turbo to support the horsepower they wish to make.
Re: best size single turbo for my setup? help?
1 Post
Car: 2000 Trans Am
I feel like I can select a decently sized turbo for most combinations. Get an idea of what the guy is wanting to run and select something in that range.
If I were you, I would look around at what people are running on cars with similar conditions as you. You could put a big turbo on it, and run low boost in which case you wouldlt be leaning on the turbo too badly.
You could put a small turbo and to get the flow out of it, you may have to run high boost to get what you want. In which case you are going to have some trouble keeping all your gaskets dry unless you have a good vacuum system.
15psi. Hmm. Youd probably be able to get by with a 64-70mm compressor wheel. That will make for decent mid range power out of the turbo and with good gas and maybe water/alky injection you can keep from burning holes in your pistons.
You will also want to decide what type of fuel you run. 15psi with that kind of compression, I would run C16 at the race track or anytime you are going to see full boost, simply for precationary measures.
Or as someone else mentioned, you could step up to a larger turbo, and lower boost. Perhaps Im talking out my *** here and someone needs to correct me. LOL
good luck.
it wouldnt hurt to try again to get in touch with a shop that knows what they are doing. That is what I did.
good luck.
The turbine side is greatly effected by the factors that you’re stating, as well as engine tune, turbo manifold/header construction and his exhaust. That is the reason that I didn’t bother recommending a turbine side since I do not have enough info to decide that (for that matter, that’s usually an educated guess anyway)
83crossfire:
I have pondered what you said for a while and all info I have seen/read, etc. says that 1 BAR equals 1 atmoshere, which is 14.7 PSI (at sea level, etc, etc), where did you find this info out ?I'd be interested in seeing more.
Also the compressor side (again) from the info I have read/seen, etc also has a dependany on use, not just a direct relation ship, if you look at superchargers (centrifugal ) you will see a varition on sizing, trims, and drive ratios for similar applications, so this supports that theory.
I do agree turbine side is a little trickier to decide on, but I'm sure there is some calculation somewhere that would get you into a close balpark as well.
The compressor maps, do only account for displacement and PSIG that is desired to read, but even after that, most people will say they are just a close guide, not nessisarily the "end all, be all", I haven't see a way to read them that takes into account actual VE, runner length/size, or other things that may or may not effect the outcome.
Best way I've found to get at least close with a turbo size, is look at what other people/manufacturers are using for a similar/same set-up and use, and base yours off that, with maybe a little bit educated guessing, as to "improve" upon that.
At no point did I say that what you wrote will not work, just that I don't see how that it would be "best" without knowing everything about the car.... *shrug* It may be the best combination ever, who's to know without trying it?
Just my $0.02
Just my $0.02
Oh and for finding approximate turbo sizing, I used to use this site, but now they just list Garret GT series turbos for all applications, but it does still list some compressor maps.
Might give you some ideas though.
Some calculators
Some calculators
1 bar = 14.50377 psi
1 atmosphere = 14.69595 psi
1 atmosphere = 1.01325 bar
I donno, do a web search for conversion factors, someone out there will probably have it right.
To be honest, I’m not positive that I understand what you’re getting at with this anyway. I understand that there are subtle differences in the shapes of compressor maps which could make one turbo a significantly better match to a specific application then another even though both may move the same amount of air. But that is exactly what I took into account. I took into account his best description of what he has and what he wants and gave him an answer based in the turbos that people can commonly get. Notice that when his responses changed slightly so that he needed to move LESS air at a LOWER pressure, I actually recommended a larger turbo. That was because of the shape of the compressor map and where those needs fell on the compressor maps.
This is not a simple “he wants X hp, which will require Y airflow which Z turbo can provide.” Although that will probably get you a turbo that could be made to work, that will probably not get you a great fit and will probably result in you pushing the turbo to the ragged edge...
FWIW, you’ll also probably need to find some way to compare different “frame” sizes (ex, a .83 T03 will spool well on something as small as a 3.8L, where a .83 T08 will be slow to spool on a 350), and even worse, some way to convert different manufacturer standards, specifically Holset many others just designate their turbine sizes by nozzle area (the A in A/R) and ignore the radius.
The VE and power band are related (the torque curve and VE curve will have EXACTLY the same shape), and you can use one to predict the other. Harmonic tuning due to runner length and exhaust design does become a variable in this equation, especially since in almost all cases you loose the scavenging effect from exhaust, but typically, the best tuned setup only gains or looses about 7% in this area… something that is more then encompassed in the size of an appropriate compressor map.
Copying someone else’s setup is only appropriate if the setup is very similar to yours, and it will only be as close a match as their setup is, which is probably only as close as a combination of how good the advice they got was, how closely they followed that advice and how good a selection they had to choose from. The fact is that in the performance world it seems like anything that gives any improvement (and even a grossly mis-sized turbo would give an improvement) is touted as great by those that spent their hard earned $$$ to buy it an put it on their car.
If you insist on taking that approach then I would suggest that you find the people that get unbelievably good times out of parts that you don’t believe can deliver those times, because they usually know something that the rest don’t, and then copy the combination to the letter. (FWIW, every car that I’ve ever owned has been accused of being a factory freak, and then I’ve been accused of misstating mods… the latest thing that I’ve spent a lot of time on, my brother’s car, using one M90 blower is running mid 11’s at 120mph in a big 4 door, and I guarantee that it will see 10’s by the end of the year. I don’t know of anyone that has run faster then high 12’s in a similar weight car with just an M90. Take that however you want)
Just my $0.02
Just my $0.02
Some calculators
Some calculators
You guys are talking WAY over my head with those figures your throwing out, but I wanted to add my 2 cents. A friend of mine has run as high as 24 lbs of boost on his small block with 10.1 compression, but he is running C-16. His motor has made several passes down the track with no problems.
got some responses
Turbonetics said...
T-76 with Q-trim
Innovative Turbo said...
T-72 with Q trim and they said it was actually a GT-72 and they also said they manufacture their own turbos. true?
Turbonetics said...
T-76 with Q-trim
I gotcha bar, it's about 12" long and has more boost than yo mamma's 1969 hair dryer! So gitcha some of that... with some milk of magnisia and a tube of preparation H! Whatcha think about THAT????
1 Post
Car: 1992 B4C 1LE
Originally posted by bad_turbo
T-netics and Innovative both manufacture their own turbos.
Terrell351
06-13-2021 01:13 PM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
