Carb Hats?!?!?!?!?!?? please help
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Hi I have been lookng for carb hats everywhere. can someone please tell me where I can find them
Ps- I checked procharger.com and was unable to find them please help! thanx.
1 Post
Car: 1989 Iroc Z L98
Email the owner at this website and he should be able to hook you up with one from procharger
www.tenperf.com
Ebay would be another place to check but I don't see any on there at the moment.
www.tenperf.com
the quality control on them is fair at best, normally when you blowthrough them, you should have the carb mounting flange of the bonnet machined flat to get a good seal, and keep from having a boost leak.
adam
adam
Originally posted by onebadwagon
k&n makes a decent one, you just have to have it machined flat before you put boost through it.
Originally posted by 83 Crossfire TA
The K&N one was not designed for use in a boosted application, but where there isn’t enough room to mount a correct air filter and you need to relocate it someplace else. It’s not tall enough to be used with boost and will make tuning a carb under boost just about impossible.
Supporter/Moderator
I picked up a turbonetics carb hat for $75ish 2 months ago. Everything even fits under the stock hood! It's on the 89 Camaro, Accel Pro-ram intake, Force EFI 4 barrel throttlebody. Everyone else wanted twice as much...
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
