I need a pic of a v-belt Paxton SN93 setup
I bought a used SN93 off of a kid I know for $300. It came with the blower unit, bracket, crank pulley, and the 180* tube. It's missing the intake tube and crank pulley. Is there anything else I'm missing that I don't know?
Also, I'm going to be using this on a 98 350. Besides obviously switching the accessory pullies to utilize the v-belts what else will I have to do? Will I still be able to keep my a/c or do I have to ditch it to use the supercharger? Keeping the a/c would be a plus but obviously I'll ditch it for the charger if I have to.
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
V belt pics
Here is a picture of my 87 z28 with a Paxton. As you can see, I don't have the A/C anymore. If your car is 88 or newer, it would be alot of work to make this work. If more pics would help, send me a message and I can get more pictures to you.
hey
Could you post a pic looking down at more of an angle so I could see more of where the belt is routed?
Thanks a lot.
Also, All i have is the headunit and pulleys so I need to make my own bracket which isn't a big deal but can I order the SC to TB pipes from paxton still? It would just be much easier than trying to make my own.
Thanks a lot.
Hotrodboba400
12-10-2019 07:07 PM
