Turbo: T04B 1.15 / .60 Good for 350?
Found it on Ebay. What exactly is it good for?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875200695
Also found this for carb+turbo setups:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874684556
And is this any good? better than the T04B? what?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875048700
also found this:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875163469
isnt that sick? Do you think that would even work?
also found this:
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: Turbo: T04B 1.15 / .60 Good for 350?
[url]
also found this:
[url]
also found this:
The hilborn is way sick
The wheel is what is important.....housings are easily swapped but if you dont have a good wheel, you are gonna have to buy one
i should make a webpage with all the measurements of all the wheels both compressor and turbine so that way anyone interested can ask an ebay seller to measure and then check it via my site
For instance.....i'll have a T04E big compressor housing (4" inlet, 2.5" outlet) and a 60trim T04E wheel for sale soon. The 60trim T04E wheel is good for about 450 or so i believe by itself compared to the 60-1 wheel from the T04b which is good to about 600hp. Both wheels are very similar in size also but are much different when used
60trim E wheel = 2.17 inducer and 2.95 exducer
60-1 B wheel = 2.32 inducer and 3.00 exducer
NinjaNife
08-23-2015 11:49 AM
