66 - 72 mm turbo?
Car: 1988 Mustang GT
Engine: 302
66 - 72 mm turbo?
I'm building up the 327, looking for anywhere between 500 to 700 hp... turbo, think I can pull it off with a single 66 or 72mm turbo?
You could go even smaller depending on what horsepower you REALLY wanted
a 60-1 would get you 500-550hp at a reasonable boost level of maybe 10-15psi with a decent set of heads and closer to 600 with about 20-24psi
It would spool like mad too.....another good turbo would be the T63E that precision sells. I believe that turbo is good to almost 700hp and spools pretty damn fast also
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
A few people I know have been running a TE64-1 turbo as well with good results
Hey guys, if you are looking to buy a turbo, wait until March or April, I was talking to Harry at Precision Turbo, they have the GT series turbos coming out soon and all I have been hearing is that it spools up like crazy, a GT series 72 will spool up quicker than a the regular 63 and make much more power than a regular 72.
Good luck
Prasad
Good luck
Prasad
New2Chevy
09-28-2015 12:35 AM
