N20, How much shot can I run safely??
Old 11-06-2002 | 11:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've got a GM Goodwrench 350 (12k miles on it) , dished pistons, aluminum Pro Lightning heads 64cc, will have around 9.3:1 compression. Also, Comp 268xe cam.
How much can I safely run for now?? I was thinking a 100 shot.. Next yr I plan on stroking the motor with different pistons, and raising the compression a little.
Any recommendations on what to get?? This won't happen till spring at the earliest anyways.
Old 11-07-2002 | 12:32 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Nitrous Express Hitman plate system...adjustable from 100-200 horsepower and can be upgraded at a later time to go up to 300 horse shot.With your bottom end (pistons mainly) I would go no higher than a 150 shot..but stay safe and go with a 100 shot.You can get the kit for around $360 in Jeg's.I am very happy with this sytem on my Z.
Old 11-07-2002 | 09:01 PM
TBI305Camaro's Avatar
I was thinking about running alittle nitrous myself.
Old 11-09-2002 | 10:50 AM
B4Ctom1's Avatar
Car: 1992 B4C 1LE
for a 305 or a Goodwreck 350 a 100 hp shot is a safe bet. you could run more on either, but its about pushing your luck.
Old 11-09-2002 | 07:08 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by B4Ctom1
Goodwreck 350 .
I take it that wasn't a typo
Old 11-12-2002 | 11:21 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I've been running 100 shot in my bone stock '85 IROC for a couple months now and haven't made piston puree yet
Old 11-13-2002 | 08:10 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
A couple of months now???? Spray more!!!!! If it ain't broke..you ain't sprayin' enough!!Just kiddin man...see proof positive a cast piston motor can take a 100 shot..bet it could go a 150 shot though!!!:lala:
Old 11-13-2002 | 09:02 AM
B4Ctom1's Avatar
Car: 1992 B4C 1LE
I give em a bad rap but I guess they get the job done, they're all new atleast.
Old 11-13-2002 | 11:37 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Hahaha, I would but the car has been sitting. It runs, kinda, but likes to turn itself off at stoplights and when you put it in park. Bad MAF I believe.
I'd like to go to a 125 shot. The engine is original and has 77k miles on it
Old 11-13-2002 | 01:09 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
The IAC may need adjusting if the car is shutting off like that.Just another idea...had that problem in my T/A and adjusting that fixed it.On the n2o issue..had a friend that would spray a 150-175 shot on his stock L98 with 180,000 plus miles..when he replaced the motor with his new 355 it still ran strong..consistent 13's on the motor...NOSFEDGTA.Psycho yeah..but he did it.Your iroc with 77,000 can easily go 125-150 shot.
Old 11-13-2002 | 04:54 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
That's good to know. Is there somewhere I can go to find out which jets to put in? It's an NOS system...I'll check out Holleys website.
By adjusting the IAC do you mean setting the minimum air? I'll give it a whirl. The poor car is just sitting across the street
Orr89RocZ
04-25-2016 08:28 AM
fasteddi
09-02-2015 10:29 AM
ezobens
08-19-2015 10:29 PM
86White_T/A305
08-17-2015 12:16 AM
mizz0313
08-12-2015 06:45 AM
Quick Reply: N20, How much shot can I run safely??
