Max boost on an LB9 w/D-1SC ???
Old 06-15-2002 | 04:12 PM
92GTA's Avatar
I'm going to buy the ProCharger D-1SC for my project car but before I put the new engine I'd like to have some fun killing the original LB9. What's the max boost that I can run on a factory LB9 and not instantly blow it up but just about have it maxed out???
Don't worry, I'm not killing a perfectly good engine here. It has 150K miles and was never mantained correctly. It puts out blue smoke on heavy acceleration and smokes when you start it cold BUT it runs really strong still
Old 06-15-2002 | 10:38 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Alex, you really wanna drive over your crank don't you
Old 06-15-2002 | 11:38 PM
92GTA's Avatar
What do you mean I know that the D-1SC is waaaay too much for the factory 305 anyway but what the hell 15-20lbs of boost never killed anyone
Old 06-16-2002 | 12:03 AM
Astro's Avatar
Theres always a first
Old 06-16-2002 | 11:14 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
But a rod or two comin through the fire wall could! :lala:
Old 06-16-2002 | 12:00 PM
92GTA's Avatar
All joking aside, is the D-1SC just too much for a factory 305 even w/the minimum boost?
Old 06-16-2002 | 12:39 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Well, let's see.... the D1SC with a 4.00" blower pulley is "rated" at 10-psig on a stock 350 at ~5,200 rpm. So on a 305, I would assume slightly more boost would be attained but I'm not qualified to say how much because mine is far from stock. I attained 8-psig.
With a 3.70" pulley, I got 2-psig more. This pulley spins the impeller 8 percent faster. So let's say you went with the largest blower pulley, 4.25". This would slower the impeller 6 percent. Based on the 10-psig rating above, the 4.25" pulley should result in 8 to 8.5-psig boost on a 350. Making an assumption that you'll get ~2-psig more on a stock 305, that yields 10-psig with a 4.25" pulley. As long as you run an intercooler and an aftermarket ignition, you should not have any catastrophic events.
BTW, once I get the twin hi-flow intercooler setup on my car, my three-core IC will be for sale.
Old 06-16-2002 | 01:00 PM
92GTA's Avatar
So woth the 4.25" pulley and say a standard MSD ignition I'll be alright, cool.
Actually I'd like to copy your dual setup for my final project.
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
$750 L98
11-07-2015 02:26 PM
Gordonr1973
09-29-2015 11:59 AM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: Max boost on an LB9 w/D-1SC ???
