Piston ring gap, twin turbo SBC?
Old 06-11-2002 | 09:53 AM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
I know .004" per inch or bore is generally used for NA engine's, but what about turbo applications? This is a TT SBC 427, 4.125" bore, forged JE pistons, street engine, pump gas.
Old 06-11-2002 | 12:30 PM
ATOMonkey's Avatar
Since Turbo's tend to run a little hotter you should open the gap up a couple thou. I'll check around today and see what we run.
.016" Compression ring gap. That's going to be the biggest gap because it's the hottest ring. Hope that helps
Old 06-11-2002 | 09:28 PM
Monty's Avatar
Thanks for the reply. .016" seems pretty tight for a forced induction application. I ran .016-.018" on my 650hp NA SBC 427. My machinist recommended as much as .030"-.032", but he normally deals with turbo/super charged NMCA/NSCA and NMRA racing engine. So I thought that seemed a little wide for a low boost (15psi or so) street engine. I was thinking something like .026"-.028" for the top, and .024" - .026" for the second ring. I was just wondering what the other forced induction guys set there's at. I'm starting the final assembly tomorrow evening, and we're dynoing next weekend.
Old 06-12-2002 | 07:22 AM
ATOMonkey's Avatar
.016-.020" is what we set the new 6.0L Powerstroke to. Going wider never hurts endurance, but can effect performance. Whatever you deceide, good luck on your build.
Old 06-12-2002 | 08:47 AM
Monty's Avatar
ATO, thanks again!
Old 06-12-2002 | 12:59 PM
crazeinc's Avatar
check out your post over at the NMCA board, the guy that responded seem to know his stuff.
Old 06-12-2002 | 01:18 PM
Monty's Avatar
Thanks, I forgot I also posted over there...
Old 06-12-2002 | 03:15 PM
Guido's Avatar
Car: 2000 Trans Am
Monty, we used .028 on my top ring and .024-.025 on the bottom ring.
We went by the instructions that came with my pistons and were liberal with the top rings. If they filed a hair over were not too worried about it due to running higher boost levels.
Good luck.
Old 06-12-2002 | 07:14 PM
Metalifann's Avatar
Sealed Power recommends .006" of gap per inch of bore diameter on a supercharged application. I imagine turbo would be the same.
Old 06-13-2002 | 12:37 AM
BlownBird's Avatar
.026 top/ .024 bottom here!
Old 06-13-2002 | 09:55 PM
Monty's Avatar
Thanks for all the feedback. I ended up going with .026" on the 1/16" stainless steel top rings, and .022" on the 1/16" cast iron 2nd rings. I dyno next weekend, so I'll find out then if it's okay.
Old 06-13-2002 | 10:47 PM
Blown WS6's Avatar
Car: 91 Formula, 92 Vert
Engine: 350 TPI, 350 LT1
Transmission: Both Auto
I'm .020 on both.
Old 06-24-2002 | 12:34 AM
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
.026 on both for me, 8 Lbs. of boost, 355 CID engine, 144 Roots Blower 220% overdrive. Solid bottom end. 28* timing. 550 horsepower @ 6500 Rpms... then boost falls off bad, so i shift @ 6200 Just in case.
Hotrodboba400
12-10-2019 07:07 PM
86Firebird86
12-26-2015 07:21 AM
Nick McCardle
09-10-2015 08:36 PM
BOOT77
09-05-2015 03:55 PM
Quick Reply: Piston ring gap, twin turbo SBC?
