Question about a used Nitrous kit im buying
Im sure im expecting problems by getting this system, But im getting it for a decent price and the guy is about an hour away from me so i can inspect it. He emailed me and this is what he said:
the kit is a tpi kit from Nitrous
Oxide
Systems. I believe the part # is 5151. I have an S-10 pick-up with a
camaro
lt-1 engine that i've been using it on. the kit uses a plate that goes
between the throttle body and intake manifold.
I thought the Nitrous Oxide Systems TB plate systems are different between the LT1 and TPI? Am i wrong? The 5151 kit that he's selling is for TPI units. Is there any way i can visually inspect to make sure that it is indeed for a TPI? thanx for any imput.
Oxide
camaro
Car: 98 Camaro SS
Transmission: M6
I run 24# SVO injectors with my setup.
spraying a 150 shot..
I'm pretty sure the plate is different for a L98 vs. a LT1... you might want to try doing a search for TPI Plate, or somethign to that effect so you can see pics of it.. and IIRC, the N.O.S. #5151 is the correct one for a L98, they have a different one for LT1 applications.
The only differences in the kit that I know would be the plate.. so if you're getting a sweet deal, pick it up, sell the L98 plate to someone on this board, and either buy a used LT1 plate, or a new one from N.O.S.
hectre13
08-26-2015 08:17 AM
