First performance upgrade since 1990 :)
Old 04-29-2011, 05:19 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Sill need to run the fuel line from the pump and do the wiring plus get a MSD digital window switch and wideband.....also thinking about upgrading to a MSD 6-AL2 to take advantage of the custom curve with stepped boost timing control and the fact it has a sensing line for the NOS system activation for even additional timing control when the system is armed.
Old 04-29-2011, 07:48 PM
daverr's Avatar
Re: First performance upgrade since 1990 :)
nice n2o upgrade kinda overkill with that big supercharger but thats what hotrodding is all about
Old 04-29-2011, 10:50 PM
flrtin1's Avatar
Engine: S/B
Lol just a little intercooler for those mid summer nights when its 95 degrees and 98% humidity to pick back up the performance loss
Old 04-30-2011, 05:24 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
" Mower gas " prices just shot up!! LOL!!
NOS timer to come??
Old 04-30-2011, 09:51 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
all I have to say is wow!
Old 04-30-2011, 10:02 AM
flrtin1's Avatar
Engine: S/B
NOS timer to come??
Yes, yes the prices did ...really really going to hurt on the Power Tour this year.
I dont know about a progressive timer yet....figured I was going to see how hard the hit was during testing then make that decision. I have never had any experiance with nitrous before, I have been thinking about doing this for over 20yrs but never pulled trigger til now and am finding there is not a lot of info on using it with a roots blower out there!
The kit came with 100-500 jets but I am going to get the lowest set NX has (30 I think so that would make it 60) to do the inital testing, but I will also need to find out from NX what fuel pressure I will need to run with those since they are not on the chart they sent with the system.
The other thing I ran into was I had to modify the bottoms of my Carter Competiton Series carbs.....the plates were made for holleys and my Carters had some casting pockets that were exposed using the plates so I had to fill them and do a little machining so I didnt have any vacuum leaks.
Old 04-30-2011, 01:12 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Looking very sweet! Man your car just keeps getting better and better. Your leaving me no chance to catch up :-)
Old 04-30-2011, 07:24 PM
Street Lethal's Avatar
Originally Posted by flrtin1
The other thing I ran into was I had to modify the bottoms of my Carter Competiton Series carbs.....the plates were made for holleys and my Carters had some casting pockets that were exposed using the plates so I had to fill them and do a little machining so I didnt have any vacuum leaks....
How have the Carter carbs been w/boost in terms of the weighted secondary door? I know that Carter made a kit once upon a time that included varying weighted air door flaps (some heavier, some lighter, etc) to help dial in the secondaries, but it was discontinued a long time ago. How are they under boost?
Old 04-30-2011, 07:48 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
thats crazy dude..lol..not only the car but that you havent modded it since 1990 you GOTTA have other projects right?
Old 04-30-2011, 08:09 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
WOW looks NICE!! how much hp does that car have?
Old 04-30-2011, 11:23 PM
flrtin1's Avatar
Engine: S/B
I got those when I had the 144 on it back in 86 (I was running a dual carb adapter on the 144) and they have been great....I never have seen a weighted kit for them but that was long ago lol....
Old 04-30-2011, 11:25 PM
flrtin1's Avatar
Engine: S/B
hahaha you are doing a fine job "keeping up" Dave
Havent looked at your thread today....is the rear done? We did some cruising last night and didnt see ya.
Old 04-30-2011, 11:28 PM
flrtin1's Avatar
Engine: S/B
Dont know for sure...........but it sure is fun to drive
Old 04-30-2011, 11:37 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
No the Rear is sitting under the car, but not attached. I ordered a stainless brake line kit from EBmiller that has not showed up. I am debating if I should install without it.
Then I got the bright idea to change my fuel lines over to Teflon. So I did that today. That is pretty sweet! I routed them through the trans tunnel and you cannot see them now. It cleaned it up a bit and it has been holding pressure for the last 3 hours!
I also decided on a better cutout. I can't leave well enough alone.
Sounds dreamy and Now my car can be all the way quiet again.
I may hoist the rear in tommorow.
Old 04-30-2011, 11:48 PM
flrtin1's Avatar
Engine: S/B
looks good, better get going man I think the monsoon season is over atleast for a little bit and you need to get some break in time before the PT.
Old 05-01-2011, 12:12 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I bet it's real fun i wouldn't mind driving it lol
Bubbajones_ya
07-06-2024 08:32 PM
J-money
01-04-2019 09:45 AM
scottmoyer
09-07-2015 07:06 PM
84 TA NV
09-06-2015 08:02 PM
tgp1990
09-04-2015 06:24 AM
Quick Reply: First performance upgrade since 1990 :)
