Whelp, it works (for those of you following my turbo build)
Old 07-24-2009, 04:34 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Yup, after a horrible vacation of wondering why the hell the car wouldn't work, we went back to the basics. We took off the hose connection on the bowl vents because the car kept stalling out ( guess it only works for some =/ ). After that we were able to get the car running but it still didn't respond right. After all that we took the fuel filter off the carb to see if it was acting as a restrictor, and gave it a by ear tune, the narrow band was reading the last yellow of stochiometric right before being rich.
Since starting it sounded a hell of a lot better, a lot less sluggish too. Drove it down the block, brought it up to about 3000rpms and let off the gas and the tires chirped so I had a good feeling after that. Swung around and headed up the other block and mashed it, and wow the tires wouldnt stop spinning, second gear shift chirped and spun, third gear sqeauled and spun, I have a feeling I'm gonna have to get slicks or something.
At least I'm on the right track now, I gotta order a wideband and get the tuning narrowed down even better because there was a tiny hesitation ( 1/10 a second ) between the N/A to BOOST transition, but in the end it turns out that just simply turning the screws in about 3 turns from what they were, and adjusting the timing a tad bit might have actually done it. The idle seemed to get better and the engine ran better with each turn in plus finally the AFR gauge finally started to come out of RICH.
All I can say is I appreciate all the advice you guys gave me, I mean I can't narrow it down to exactly what did it, but I'm sure it was a combination of the Boost Timing Mock Up, the Fuel Pump Mock Up, and the Ignition System. I can't wait to take it to the track now!
Thanks again,
Jim
Old 07-24-2009, 04:41 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Whelp, it works (for those of you following my turbo build)
That is good to hear that it is running good now. Keep an eye on it and don't go too lean. The fix was probably a combination of fuel and timing. Boost setups are sensitive to this.
Good job. Have fun at the track. Bring a helmet.......you will need it for the ET you should be pulling.
Old 07-24-2009, 04:52 PM
I just noticed the fuel bowls are completely topped out, guess thats because the fuel is able to flow a hell of a lot better now, I'm gonna have to lower them again, boy is that a pain in the a**. To think, I was just about to spend $3000 on a fuel injection setup lol
Old 08-04-2009, 08:15 PM
TwinTurboROC's Avatar
good to hear you gettin the bugs worked out, i was worried you might have bailed on the whole project the way it seem to be going.
Old 08-05-2009, 12:44 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
good to hear. enjoy it
Old 08-06-2009, 12:27 AM
EvilCartman's Avatar
Car: '82 Z28
Glad you've got it running better
Old 08-10-2009, 10:13 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
i just spent a while reading your other thread and this one. Glad to hear you have figured most of it out. what did you end up setting the timing to? and how is the engine liking the 15psi??
Old 08-31-2009, 10:07 PM
so whats the new update?
Old 09-02-2009, 11:15 AM
blew the head gaskets lmao, so im doing an engine rebuild, just about done, gonna be running only 5 psi for the winter and to make sure the motor doesnt blow again
Old 09-02-2009, 03:07 PM
.sounds like its time for some arp head studs. did you ever get a wideband o2 sensor for tuning??
Old 09-24-2009, 09:58 AM
TGO - 10 Year Member
Street Lethal's Avatar
blew the head gaskets lmao, so im doing an engine rebuild, just about done, gonna be running only 5 psi for the winter and to make sure the motor doesnt blow again....
I'm glad to hear that the turbo header setup is holding up so far. I'm still considering buying a set from ssautochrome on another 3rd gen project that I recently picked up, just to mess around with on the street, and cap it at 15-psi. Lemme know when you get the engine done, as I'd like to meet up one night to see the setup in person. We're always by e-town on Wednesday an Friday nights, so if you can get her down before the season ends that would be cool. By the way, did you go with cometic head gaskets this time around....?
Terrell351
06-13-2021 01:13 PM
Jake_92RS
01-28-2020 10:37 PM
Vintageracer
01-10-2020 05:33 PM
jharrison5
08-19-2015 05:53 PM
makaveli09
08-12-2015 09:07 PM
Quick Reply: Whelp, it works (for those of you following my turbo build)
