f1-R 383 done on the stand....
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Here it is......all together save for intercooler and tubing (gotta build a frame for that on the dyno stand) finally...
in case anyone missed the specs, just search for recent threads in here from me, with more pics and stuff....
its an F1-R procharged, intercooled, methanol injected 383 SBC
should have it on the engine dyno in a week or two
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01576.jpg)
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01577.jpg)
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01578.jpg)
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01579.jpg)
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01581.jpg)
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01582.jpg)
![](http://i51.photobucket.com/albums/f391/383backinblack/car%20stuff/DSC01583.jpg)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: f1-R 383 done on the stand....
Nice!
it doesnt look very hood friendly, will it fit?
ahh, cool. I kinda figured there had to be a little bubble or something over by the blower. Im toying with the idea of getting a procharger for my 408 in the future. Should be sweet, but i guess i would have to chop up my hood as well.
depends which blower......if you want an f-series....definitely....and you're wheel well
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Holy beefy blower bracket. What block did you go with?
Car: 91 rs
Axle/Gears: 3.50 9"
That motor is FBA!!! FBA!!! Had to say it twice. I dont know if I would have dished out the cash for the AFRs though. Maybe an RHS with a larger intake runner. Dont mean to pick your motor apart, I just wonder how much more power it would make with the AFRs over a larger inferior head with the boost.
You wouldnt want to hand out those custom cam specs would ya?
Hows that car work with that trans? Id like to get one to make driving a little more fun over my manual th350.
What tires did you run? Did you hook good? What tires for the new setup?
Sorry for the questions but Id like to get up to your power level in two years or so. Might go with a boring turbo though.....
Ferggin Bad A$$ engine man.
thanks man......
the afr heads have superior port velocity and mid lift flow (even the older heads like mine) than everything else out there, thats why no matter what flow numbers other companies throw out there, they always get flogged in dyno tests by AFR. as far as cost goes, i've had the heads for years......from when the car was naturally aspirated.....in fact thats about the only thing thats left from my old motor
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
the trans works mint thus far....the cam is huge, so it wouldnt be nearly as streetable with an auto.
i dont have the card in front of me, but i believe the lift is .630/.630 and the duration is 262/272 at .050 on a 114LSA (its installed 3.5 deg advanced)
the car hooks good.....mickey thompson et streets......it had 26x12.5's on it, but now it will have 28x12.5's.......its got more to do with suspension than tires though
Car: Used to drive a camaro
Holy god of war!!! That is nice. That is a rear killer for sure...I'd be very interested to get some 1/4 passes with that. Post up times and dyno #'s once you have them.
Car: 91 rs
Axle/Gears: 3.50 9"
I have 29x12.5 sportsmans on my car now. I just had to do a little beating in the well. I put stiffer springs in the rear, as I heard with an auto trans and stock suspension you want stiffer. So they dont come near the lip, but when I get her to the track and launch it...might be a different story.
Are you sure that cam is 262/272 at .050!?! Thats some wild duration.
So you just have to rig up the exchanger and its ready to dyno?
if your suspension works right, the rear of the car should raise up, not drop down. if its dropping, the car is trying to pull the rear tires up, and you're losing traction.....if its raising, then its pushing down which is what you want
Car: 91 rs
Axle/Gears: 3.50 9"
Right. Right now the control arms are parallel. Whis is supposed to be the best place if you hook. Keeps all force going forward. If I get sloppy, then Ill get some rca brackets.
A lot of people talk about cars squatting and how good that is, couldnt be farther from the truth.
Why do you need that much duration with a blower? I didnt think you could even get that kind of duration with a lobe sep that high.
and yes, you can lol
Car: 91 rs
Axle/Gears: 3.50 9"
Im running a xr288hr 110 lobe. I was told it would be good for me. But that was back when I was running 7-8lbs. Id like to push more like 12-14 this summer and I'm wondering if I should change the cam....
Cant wait to see those numbers man! Hey whats the benefit of running both a cooler and meth? I thought just meth was good enough.
preston smith does the same thing in his turbo iroc, and after the intercooler he was seeing an additional 40-60 degree reduction in air intake temps when the methanol turned on.
Car: 91 rs
Axle/Gears: 3.50 9"
ya, thats what the companies that make the methanol kits want you to think lol.......alot higher boost you need all the help you can get to keep the temperature down.
I wish there were some way to test a cam without trial and error.
I dont really want to hit solid 9s with my car. I dont feel like installing all the safety stuff. Well see what happens this year. Should be mid 10s. If I want to go faster, I should really upgrade my block. I have an old block thats stronger, Id probably put a solid roller in it so if I need to change my cam I'll do it then. Or maybe a 406.....if I think I can keep the traction.
Interesting, at what pressure would you say both are worth the cost and work?
Car: 91 rs
Axle/Gears: 3.50 9"
Maybe ill have to get an intake air temp sensor. I have a snap-on needle thermometer, but I dont know if it would be good enough. It would be interesting to see where I stand with just the meth.
Car: 91 rs
Axle/Gears: 3.50 9"
I thought it was a TPI....a new short runner style. Just two injectors though, thats definitely not enough for that turbo you have there. And whats all that doing on a Ford block?
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
duuhhh... i was so caught up with everything else... i had figure it out, but i had already posted the question... couldnt delete it.. rofl
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
looks awesome man! huge blower!!
NOt that it really matters since old afr's are still good heads and you'll make your power, but you could consider the new Eliminators from AFR... They kill the old AFR heads in all flow ranges and velocity. Just a thought down the road if your looking for a tad bit more power
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
NOt that it really matters since old afr's are still good heads and you'll make your power, but you could consider the new Eliminators from AFR... They kill the old AFR heads in all flow ranges and velocity. Just a thought down the road if your looking for a tad bit more power![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 91 rs
Axle/Gears: 3.50 9"
Have you thought about running a vacuum pump at that boost?
Car: 91 rs
Axle/Gears: 3.50 9"
I thought there were some that were claimed to be ok. They didnt require as much oil or something. I was also reading about using a Ford smog? pump found on the new cars and trucks. Electric driven, so you could control it. Just need a oil separator, doesnt like oil in it I guess.
One thing I had thought about doing though was to run a hose to the end of the header, just for the track though, when I have the exhaust system off, or an open turn out installed.
man I'm glad to see that bracket in action. that's pretty much what I ended up with for my F-1 on an LT1. since it's in a thirdgen, neither the 3rd gen or the 4th gen brackets would work, ended up getting a universal SBC bracket that looks pretty much exactly like what you have. mine just isn't a cog setup
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
i have exhaust powered crankcase evacuation....works fine all the time
man I'm glad to see that bracket in action. that's pretty much what I ended up with for my F-1 on an LT1. since it's in a thirdgen, neither the 3rd gen or the 4th gen brackets would work, ended up getting a universal SBC bracket that looks pretty much exactly like what you have. mine just isn't a cog setup ![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Last edited by 383backinblack; 02-13-2008 at 12:11 PM. Reason: Automerged Doublepost
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
My F1 is setup with a 12rib serpentine. Do you think its going to do burnouts?
is it an f1-R? if it is, theres no way you're going to turn it all the way to 68,000 rpm with a serp belt......thats the whole reason for the existance of the HTD/GT profile toothed setup......in order to even try it, you'd need some EVIL belt tension......i wouldnt even chance it
Car: '02 Z06
Engine: L33 5.7
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Not picking on the setup. However any reason you didn't do a reverse superchargeer setup or a remote waterpump? So the supercharge could be more inboard. Also did procharger know this was going on a 3rd gen? Cuz they give a differnt setup (blower outlet facing the driver fender). Maybe if you say carb they send it that way?!? I like it!
http://www.gilsbachracecraft.com/bil...nior/index.htm
Can't find my pics of the remote waterpump. They are nice cuz they free up a lot of room on a race car all you need is alt.,crank,and maybe vacuum pump all can run off a very small v belt. A then drop the engine lower and run the supercharger outlet tube in the car to a water/air cooler, then out to a reverse intake. Just some thoughts.
Car: 91 rs
Axle/Gears: 3.50 9"
I heard the exhaust evacs dont work well with any kind of backpressure, such as mufflers. If you found this not to be true, I'm very excited!! I run a dual 3" with dynomax welded mufflers. Should be very little backpressure.
Do you run one hose off the valvecover? Or one on each side?
thats a small block blower bracket, there are other setups like chain drives etc that mount it the other way made by other companies but its not really necessary for an f1.....thats what procharger makes.......the f series blowers arent really application specific, the listed application is "small block chevy, race"
air/water intercoolers are pretty lame for street cars, i like to be able to have a passenger so thats out anyways......and if the blower discharge faced the fender with the bracket itd be a huge pain in the *** as it would have to run the tube THROUGH the fender to get anywhere. You're probably thinking of a reverse rotation blower.....they have those.
If you put the blower anyplace else in the engine compartment it'd be in the way honestly.......and it'd be even more difficult to route the tubing, the way that thing is setup there is only 4 major bends in the entire tubing system.......with 3 piece of tubing.
theres one on each side
Last edited by 383backinblack; 02-14-2008 at 08:51 AM. Reason: Automerged Doublepost
#44
Last pic..........
It's a 415cid SBC
Custom blower cam (Cam Motion)
AFR 210cc Eliminator cylinder heads
Hogan's custom sheetmetal intake
Direct port NOS system
Procharger F1R
F.A.S.T. XFI with complete data aquisition gear (i.e. pyros, accelerometer, etc)
Engine is complete just needs aftercooler piping.
Dyno session soon. Desperately waiting to get it into a car (preferrably Guido's old blue IROC if anyone can get him to get back with me).
It's a 415cid SBC
Procharger F1R
#45
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
#47
i dunno how much experience you have with these blowers.....but the f1 pulls so much air, that air filter will cause enough of a restriction that it will eventually start to pull oil through the output shaft......happened to me 3 times in one summer. The guy that runs the shop at procharger told me "anonymously" to ditch the air filter.....its been ok since then. It's not like the car gets drive 100k miles a year in a dustbowl anyways lol.
its cammed to run up to 7500 rpm, after we test that if there isnt anything else that needs to get on the dyno right away, i want to pulley it WAY up and max the blower out at 6500rpm, see how much torque it'll make with all the boost coming in down low like that.......maybe it'll go quicker haha......it'll most likely make less power that way, but it might get down the track faster.
Last edited by 383backinblack; 02-14-2008 at 03:57 PM. Reason: Automerged Doublepost
#48
Nitrous will act like an anti-detonant. They used to use it back in the day on high altitude, supercharged airplanes. A small (reasonable shot 50hp) will help drop air inlet temps significantly. I will be injecting methanol as the supplemental fuel. All controlled by the FAST XFI nitrous enrichment features.
#49
Car: 91 rs
Axle/Gears: 3.50 9"
Well thats something I didnt know. What do you mean by supplemental? Mixing it with the nitrous in a wet setup?
#50
As for the lower end:
GM CNC bowtie block (splayed 4-bolt caps across all journals {not just the center three}, siamesed cylinders, o-ringed block, blind head bolt holes, 3/4 filled with block filler)
Bore: 4.125"
Crank: Callies forged 4340, 3.875" stroke
Rods: Lunati ProMod 5.7"
Pistons: JE 26cc "dish" custom
Cam: Cam Motion custom blower spec solid roller
Timing Chain: Jesel Beltdrive
Pan: Custom fabbed aluminum by Stef's
I will get back with you on the drive ratio/impeller speed. I did all the calculations last year and I will have to dig them up when I get home. I believe it set for 24psi at 6500 with a max impeller speed of 64,000 rpm.
I agree about the air filter. I have been using an F2 on a almost stock 502BBC and I had the same thing happen with rear blower seal. I have since gone to a conical inlet with mesh screen. I suppose this engine will be no different.
Bore: 4.125"
