check out my new power adder!!!!
Old 06-04-2008, 12:23 PM
  #151
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Re: check out my new power adder!!!!
the problem was the cam and lifters. The A/F was 10.8-1
Old 06-04-2008, 12:44 PM
  #152
Street Lethal's Avatar
I'm honestly thinking that it wasn't the size of the other cam per se, but how the other cam was installed by the engine builder; it might have been installed retarded, and/or advanced, having an effect on desired timing (with the tuner assuming it was installed straight up). In any event, I'm glad you got it all fixed, now get us some video of it as soon as you can.
Old 06-04-2008, 02:10 PM
  #153
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Strange. Maybe the lifters were collapsing? When and what track do you plan on going to? I'm hoping to get mine up for the first time this weekend to Maple.
Strange, I wonder if the old lifters were collapsing? When and what track do you plan on going to? I'm hoping to get my car to Maple for the first time this weekend.
Old 06-04-2008, 04:00 PM
  #154
Transmission: t56
Thats a good possibility the first cam was advanced or retarded I just didn't want to take any chances.
I will post some videos when it is all done
The old lifters were collapsing.
I will go to maple for sure, I also plan on going to island. The only thing stopping me right now is the 9 bolt, I have to upgrade my rear.
I wish I was going to the track this weekend I'm hoping to at least take the car home Saturday.
What kind of ets are you shooting for?
Old 06-04-2008, 04:14 PM
  #155
Transmission: t56
Nice! 22* should be fine, but i wouldnt go much more than that. A knock sensor would be really helpful.
What was the problem?? What was your A/F ratio?
Don't worry I hooked up the knock sensor.
Old 06-04-2008, 05:41 PM
  #156
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Thats why I like the Boost Timing Master combined with a knock gauge, you can always run on the edge, where you make the most power.
Ets? Depends on how much boost I run. I should be able to hook well, and I'll probably run around 8psi on top of my 475hp motor. I'm hoping to hit low-mid 10s. When I max out the blower, probably 12psi, and add the alky injection, I should be mid 9's. Car's not legal for that though......
9 bolt? Just dont run good tires, it'll be ok. Especially with the 3.45 gears. You'll at least get a good mph. BTW, I built my Ford 9 for 1200 bucks. !!
Old 06-05-2008, 11:31 AM
  #157
Transmission: t56
Do you have any pics?
Would you want to built another 9in? haha
Thats awesome I would be very happy to run in the 10's with a long term goal to run in the 9's What do you think is a realistic et for my set up with a 9in and 3.27's and mt's
Old 06-05-2008, 12:48 PM
  #158
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I'll take some pics today when I'm trying to get it ready for the track.
I just bought a moser bolt in housing for 1000 bucks, came with moser axles. Bought a center section off ebay for 250 bucks shipped, included the gears, spool, all assembled. They are usually around 450. He worded it funny so it didnt get many looks. It was my first one, and I did it myself, so if you have any q's just ask.
Right now without traction you should be mid-low 11s and a mph of 134. If you got traction (ford 9"), you should see low 10s with the power the car makes now. Once you get that thing tuned in and timing good, some race gas, you should see high 9s at the same boost level. !!!
I screwed up when I bought my center section, I got it with 4.11 gears, before I understood what rpms I'd be crossing the line at. My motor probably stops making power around 6200-6500, if I run max boost, I'd be crossing the line around 7200. A bit high. So I'll have to keep the boost down for now until I get new gears, and get the car legal for 9.99.
Yee haa
Old 06-05-2008, 12:56 PM
  #159
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I bet you'd see a _nice_ increase with a better A/F...even on the safe side of high 11-low 12.
Old 06-05-2008, 04:09 PM
  #160
Transmission: t56
Yee haa
Thats great to hear! I will have to meet up with you at the track some time.
Whats your name?
I will be picking the car up tomorrow, so I am assuming we will get everything dialed in in a few hours.
Old 06-05-2008, 04:34 PM
  #161
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Name's Brian, or Bat for strange reasons. Probably wont make it this weekend, having issues with registration.
Cool, let us know how it rips!
Old 06-07-2008, 09:57 AM
  #162
Transmission: t56
I took the car for a spin yesterday wow! it is an animal. I was not able to take it home though still needs some tiding up.
Old 06-07-2008, 01:57 PM
  #163
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I bet. I'm sure third gear is pretty messy....We'll have to go beat up on some mustangs soon!!
Old 06-07-2008, 04:58 PM
  #164
Transmission: t56
definitely! sounds good.
Old 07-12-2008, 05:54 AM
  #165
Transmission: t56
better #'s on 15lbs of boost 620 rwhp at 6300 rpms and 550 ftlbs at 4500 rpms on a mustang dyno
I pulled on a few 600 street bikes
Old 07-12-2008, 09:23 AM
  #166
Meh, you guys are all talk.... J/K
The two of you guys need to get your azzez over here by Raceway Park, and help me lay the smack down on some GTO guys that I recently met up with. Really nice peeps, but regardless, they need to schooled/humbled....
-Rob
Old 07-12-2008, 10:57 AM
  #167
Transmission: t56
-Rob
Ill help you lay down the smack haha I need a rear though Still looking...
Old 07-12-2008, 11:51 AM
  #168
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Traction has been a big issue for me. Currently getting new tires mounted and about to start swapping gears.
Thats real good power man! Should be a 9 second car!
Old 07-14-2008, 11:22 AM
  #169
Transmission: t56
heres a pic of the engine bay complete.
I'm picking up my 9in today or tomorrow
Old 07-14-2008, 11:27 AM
  #170
Transmission: t56
also a few of the car with zr1's
Attached Thumbnails check out my new power adder!!!!-ttpic2.jpg   check out my new power adder!!!!-ttpic3.jpg
Old 07-30-2008, 11:25 AM
  #171
Transmission: t56
9in is installed.
Old 07-30-2008, 11:26 AM
  #172
^ Did you get the invite, can you make it down.....?
Old 07-30-2008, 11:45 AM
  #173
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Nice, hows it drive with the gears? I'm working on getting mine regeared right now for friday. NOT going smoothly.
Old 07-31-2008, 05:44 AM
  #174
Transmission: t56
Ill be there just let me know the date and time.
Old 07-31-2008, 05:56 AM
  #175
Transmission: t56
The car runs much better with the taller gears, I need new axles though since the drivers side one is bent which I wasnt told about by way2kool. Whats the problem with yours?
Old 07-31-2008, 10:29 AM
  #176
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Geez, you kinda got screwed on those axles.
Well, I was trying to change gears cheap, and got screwed with different size carrier bearings, so had to press off almost new bearings and press on new ones.
And the jegster tq arm with a ford 9" is a pita to change the center section. I'm hoping to finish it up today/tonight, register the car tomorrow, and head to Maple.
Old 07-31-2008, 11:03 AM
  #177
Transmission: t56
sweet!
Old 10-21-2008, 03:16 PM
  #178
Transmission: t56
Hey guys,
would any one possibly be interested in buying my twin turbo setup? Im thinking of parting out the car or selling it complete, The whole setup only has around 1500 miles on it and best dyno was 656rwhp at 19lbs of boost and 570tq on a mustang dyno. I'm kicking around going a different route. let me know thanks, John
Old 10-21-2008, 06:28 PM
  #179
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
how's the tranny?
Old 10-22-2008, 11:23 AM
  #180
Transmission: t56
The trans is holding strong no issues at all.
Old 10-28-2008, 09:58 AM
  #181
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Wow, just checked it out and jumped to the end here....
S L E E P E R!!!
Go win some money.
Old 10-28-2008, 10:18 AM
  #182
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
a boy and his car its a b e a uuutiful thing (TEAR) F'n SICK I LOVE IT.
Old 10-29-2008, 05:50 AM
  #183
Transmission: t56
S L E E P E R!!!
Go win some money.
Thanks guys!
Hey guys,
anyone?
I guess I'll have to try the classifieds
Old 10-29-2008, 12:18 PM
  #184
I'll be in Trexlertown, PA this coming Monday for work. I wouldn't mind checking it out, maybe not to buy it, but while I'm in the area... let me know.
Old 10-29-2008, 03:05 PM
  #185
Transmission: t56
you can come check it out thats not a problem, just give me a call if you want directions 215-828-2615 thanks, John
Old 11-22-2008, 10:41 AM
  #186
Transmission: t56
complete turbo kit available for sale anyone interested?
Old 02-17-2010, 10:40 PM
  #187
Transmission: t56
Back from dead for the guys who wanted banks tt kit pics
Old 02-18-2010, 06:13 AM
  #188
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Still for sale? I will buy the Miniram, Heads, cam and lifters. PM me if so, Maybe the trubos and Wastegates too.
Old 02-18-2010, 02:58 PM
  #189
Transmission: t56
I still have the custom ground comp Turbo cam if your interested?
Old 02-19-2010, 01:51 AM
  #190
IROC-You's Avatar
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
I know you were running Hydraulic Lifters at first, then you switched cam, did you upgrade to a Solid Roller or did you stay Hydraulic?
If its a Solid roller then yes I am interested, if its Hydraulic then I will pass.
BRoss99
12-07-2020 06:50 PM
backtothe80s
09-05-2015 12:39 AM
bamaboy0323
09-03-2015 06:07 AM
Brcharrelson
08-26-2015 07:47 PM
transamgta1Khp
08-17-2015 12:18 PM
Quick Reply: check out my new power adder!!!!
