Need help getting a map for these turbos...
Ask and ye shall recieve...
The intake wheels measure 1.858/2.370 and that seems to give them a 60 trim.
The exhaust wheels measure 2.008/1.819.
The intakes housings are .48 and .63 exhaust.
They were being used in a 300ZXtt and came out of the Mitsubishi Eclipse Spyder.
The markings on the intake housings are:
A/R .48 1-2
The markings on the exhaust housings are:
.63 H4 on one side and 687 97J 272-2 on the other.
The tag on the bearing housing reads:
TJ 0190J
11411-40P04
466195-2
on one and:
SH 0447J
11411-40P01
466079-1
on the other.
Thanx for any help!
A/R .48 1-2
TJ 0190J
11411-40P04
466195-2
on one and:
SH 0447J
11411-40P01
466079-1
on the other.
Thanx for any help!
I found what I believe is the map for these turbos:
You can find it here along with a bunch of other maps for all kinds of turbos:
Click here for turbo maps
Dont ask me about turbos, I am not exactly a expert. I am just a slightly knowledgeable moron.
Also, this is a map for the ones I have. I think they would be well suited for a Tutbo project like yours. Mine should be good to 400-450 or so. (With both obviously)
http://not2fast.wryday.com/turbo/maps/t3-60.gif
If your sure you have t3's, which 300zx did they come out of? Are they a factory set-up, cause all the 300zx's I've seen hade these t-25's like I've got.
How much do you want for them?
Those are capable of (each)361.8cfm @ 33+psi and still be at 74% eff.
Mine will do (each)289.44cfm @ 30+psi and only be at 70%eff.
Dave, these might be more what you are looking for!
nope i still think those are gonna be to small,looks like im just gonna stick with the twin t3/t4's.there slightly large for my motor,but id rather have slightly large then to small
If you were reaching the max on the t04's, wouldn't you be out of their eff range? The numbers given on both VW and my Garretts, were in their PEAK eff range.
What's stopping you from buying a Garrett t3/t4 that's going to be able to push your motor past 25psi, these turbos we've got just aren't the same quality.
As you said though, you've maxed out the t04. I know for a fact that the turbos I've got were pushing 25+psi on a bored 3L.
that was on the old motor
now the new engine has heads that flow 60-75 cfm better then the old heads,beteer cam and a much better intake.which means im gonna need something capable of moving more air
the only reason im not buyying a new turbo is cause i can just buy a second t04 pretty cheap,and if i did buy a new garret id just buy one large single turbo
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The A/R on the turbines of the T3's that VWDave has is the same as the T4/T3 hybrids you have now. The T04E compressor you have is better for the HP you want to have (assuming twins). From a comp. map and turbine point of view, you are better off doing what you planned on doing. That is, two T04E comps with T3 turbines.
These came off of the Z31 single turbo 300zx. I believe they are off of a 87 and a 86. No shaft play, spins very well. They have a .63 ar.
They ones you have, are off of a Z32 twin turbo which uses 2 t25 (m24) turbos.
And the A/R is also the same on the m25'S, just a little smaller (.63).
Does anyone know if I could put larger turbines on the t-25 (m-25)'s?
.63 AR.
Dont know. Only 1 way to find out.
