got most of the fabrication done on the IC tubing
Old 05-21-2006, 08:09 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
today i got the blower tubing fabricated, and assembled some minor stuff on the motor at the same time........it really wasn't all that difficult, or at least not as bad as i thought it would be.
i also made a new longer jack screw to tighten the belt, because the ati supplied one is about 2" too short for the belt i need, and they claim they don't have longer ones.......so i had to bust out the lathe again.......now i just have to finish weld everything and get it all powdercoated......
all thats left to do now is wire up the wideband controller, install the crank bolt, tighten everything up, put the exhaust back on, put the nose back on, and the driveshaft, tighten the spark plugs, install the powersteering reservoir, and the alky injection......and a few other odds and ends lol.....nothing to it
first pics are of the blower to IC pipe.....including the bypass flange.
oh ya, and i cut a small hole in the hood for the blower cog, and i think it needs to be bigger.
Attached Thumbnails got most of the fabrication done on the IC tubing-dsc01039.jpg   got most of the fabrication done on the IC tubing-dsc01040.jpg   got most of the fabrication done on the IC tubing-dsc01045.jpg
Old 05-21-2006, 08:12 PM
Car: '91 Camaro RS
more pics of the tubing.....
Attached Thumbnails got most of the fabrication done on the IC tubing-dsc01046.jpg   got most of the fabrication done on the IC tubing-dsc01047.jpg   got most of the fabrication done on the IC tubing-dsc01048.jpg
Old 05-21-2006, 08:13 PM
Car: '91 Camaro RS
more pics
heres the IC to carb hat tubing.....
Attached Thumbnails got most of the fabrication done on the IC tubing-dsc01049.jpg   got most of the fabrication done on the IC tubing-dsc01050.jpg   got most of the fabrication done on the IC tubing-dsc01051.jpg
Old 05-21-2006, 08:15 PM
Car: '91 Camaro RS
heres a couple more pics i snapped...
Attached Thumbnails got most of the fabrication done on the IC tubing-dsc01052.jpg   got most of the fabrication done on the IC tubing-dsc01053.jpg   got most of the fabrication done on the IC tubing-dsc01055.jpg
Old 05-21-2006, 08:16 PM
Car: '91 Camaro RS
heres the custom brake lines JPM hydraulics made me to relocate the prop valve....all that space is where the air filter cone goes
also, the pics of the jack screw i made for the blower idler pulley
Attached Thumbnails got most of the fabrication done on the IC tubing-dsc01058.jpg   got most of the fabrication done on the IC tubing-dsc01059.jpg   got most of the fabrication done on the IC tubing-dsc01044.jpg
Old 05-21-2006, 08:19 PM
Car: '91 Camaro RS
heres the hole i had to cut in the hood to clear the f1r head unit......it didnt miss fitting under by much, but oh well.....i'll have to get a blister glassed on there to cover it up.
Attached Thumbnails got most of the fabrication done on the IC tubing-dsc01061.jpg   got most of the fabrication done on the IC tubing-dsc01062.jpg
Old 05-22-2006, 01:15 AM
JBert's Avatar
Car: Looking
Looks great!
Question - Why did you put the BOV so close to the blower? Wouldn't it be more "efficient" being closer to the bonnet?
Old 05-22-2006, 06:54 PM
83 Crossfire TA's Avatar
Huh, it seems that you could have saved yourself some bends by feeding the blower outlet across the front of the engine to the passenger side of the intercooler and then running the outlet from the IC to the carb hat on the driver’s side… I hate tight 90’s in plumbing if I can avoid them
Old 05-22-2006, 07:38 PM
Car: '91 Camaro RS
ya but i hate criss crossed s**TTy looking tubing.....and that route is alot cleaner, and it would have taken much more tubing, and alot more bends to do it the other way...believe me.....there are only 5 major bends in the entire system and 2 minor ones that are less than 20 deg
Originally Posted by Red91CamaroRS
Looks great!
thats where ati said to put it lol
Last edited by 383backinblack; 05-22-2006 at 07:39 PM. Reason: Automerged Doublepost
Old 05-22-2006, 07:58 PM
JBert's Avatar
Car: Looking
good enough for me!
Old 05-22-2006, 09:48 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Nice job. I bet you can't wait to put your foot in'r!
Old 05-22-2006, 10:05 PM
Car: '91 Camaro RS
ya im bringing a seat cover
Old 05-23-2006, 06:59 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Looks very nice.
Old 05-25-2006, 12:55 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
That is awsome looking! Way to go. I'm running into the same problem with my install and now it's good to have a reference to go back to.
Thanks.
Old 06-05-2006, 05:41 PM
badbilly's Avatar
Car: 89 camaro rs
Engine: intercooled f1r procharged 383
Transmission: turbo 400
sent ya a pm thanks for the great pics i am in the middle of the same build and looking at the same problems. hope to be finished soon. how has yours run?
Old 06-05-2006, 08:05 PM
Car: '91 Camaro RS
seems to be running ok....now its tweak time and time to fix the hood and re-assemble the interior so i can drive it.
its HELLACIOUSLY loud.....you cant even hear the exhaust over the blower
Old 06-06-2006, 12:16 PM
badbilly's Avatar
Car: 89 camaro rs
i really cant wait to hear mine. where are ya located? im near albany ny and only a few minutes from lebannon valley dragway
gixxer92
05-18-2017 11:20 AM
no green
01-09-2016 09:22 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
FormulasOnly
10-02-2015 05:52 PM
zman1969
10-01-2015 11:09 AM
Quick Reply: got most of the fabrication done on the IC tubing
