Need chip burning help
Car: 88 K2500 Auto 4X4
Engine: 350 Headers, ported heads 1.6 rckrs
Transmission: 4 speed 700
Axle/Gears: Not sure
Hello, i have the burner and software, need some help getting started on my 1988 K2500, 350...live near milton, wa.
joe
joe
Re: Need chip burning help
Is that number on the chip or the ecm, let me go check for you...
joe
joe
Ok i have a 24 pin chip, emc numbers are,
serv. no. 1227747
860071 E280472193
16120071 amus,
the truck is from calif. auto, air, 4X4, trans is a 700 model, with 220 tbi, mostly stock, but i have shorty headers, 1.6 rockers, ported heads and dual exhaust with no cat.
eprom 2732
serv. no. 1227747
860071 E280472193
16120071 amus,
eprom 2732
what help do you need, this is a $42 definition, what programer do you have? this is a uv erase eprom you will me better off getting a flash eprom if you plan on doing much tuning like the ostrich.
Hi, i have no hardware or software. a friend burned a 28 pin amtel chip, but it wont fit in my 24 pin slot.
A friend has a burner 2 i can borrow, with software.
Do i stay with the 24 pin chip or upgrade to the 28 pin chip, and how will i make the slot bigger, with an adaptor? Does this require de-solder/solder the current chip holder??? I am new to all this, but i have been reading the blogs to understand what i have to do...thanks.
ps. we are currently just trying to shut off the egr, as i have a flat spot between 20 and 30 mph, otherwise the truck starts and runs great, i had to change out my heads due to a cracked head and went with a set of 1987 heads that dont support the egr valve. the old heads were the original 1988 heads..
thanks..
joe
thanks..
joe
If you can only use a burn2 you will have to go with a flash eprom and use tunerpro.
http://www.moates.net/g2-memory-adap...cing-p-36.html
Or this would be a better bang for the buck !!
http://www.moates.net/g2x-tbitype-sw...pter-p-86.html
you might want to join http://www.gearhead-efi.com
Thanks for the reply, so rather than shipping my ecm to them for a resolder, i can just use the adapter?
Question: 1. will the adapter work as well as a solder job in terms of being reliable? (plug in vs. solder)
2. will i get better tune-ability by just going to a full 28 pin unit? (ship to moates, they solder, ship back)?
Hi, tuned, I do have a spare ecm from a junk yard and i think its a 1227747, will that one work or should i just stay with the original one that came in the truck?
Just to be clear, your saying it would be best to solder in a 28 pin socket and upgrade the old 24 pin chip to a 28 pin?
Where can i get a 28 pin adapter? Radio Shack, or online???
Would like to get this done asap, dont like driving the truck with it running lean, as it pops thru the tbi on ocassion.
(i already have a 28 pin chip my friend burned for me, old amtel chip)
thanks,
joe
thanks,
joe
A 747 is a 747 but you might want to check the bcc before you run the eprom. If you are wanting to reprogram the old 2732 eprom's you will need to uv erase and get a different programer. to go to a 28 pin you will need an solder in a holder for the flash chip. Depending on what chip your friend used and if the .bin is in the correct offset you might be able to clip the legs.
https://www.thirdgen.org/forums/diy-...prom-info.html
TP, hello, say can i go to junkyard and just buy an ECM that has a 28 pin chip setup, then swap out chips??? (already have a 28 pin chip burned, but would like to fine tune the truck as well)
thanks,
joe
thanks,
joe
Ok, what is a calpak, where can i get more info on it, ect...
ps. hope im not wearing you out...but i do learn fast...
thx,
joe
thx,
joe
I can't remember what the calpak number is for a 5.7l in a 747 but you can reference the origin the ecm off the bcc (broad cast code ) code on the eprom and the calpak should correspond.
https://www.thirdgen.org/forums/dfi-...om-calpak.html
Ok, thx, i will see if i can find that info...
joe
joe
for limp home looks like it does not matter much
https://www.thirdgen.org/forums/diy-...tres-part.html
KO1
16
10-15-2015 05:00 PM
