I wanna play with more headlights
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
Where do I find those Trans Am headlight conversion kits at?
Re: I wanna play with more headlights
where the head lights don't flip up and replace the bezel with looks like 4th gen fog lamps you have a pic posted on your thread "peoples cars"
then how is it done?
what bulbs from what car and what kind of brackets did you use?
ok
do you have pics (close-ups) on the headlights that may help on this project. thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I remember them, and this is going WAY back now eh Doug, us driving past the airport out here and I was driving in front in that reliant.
it was like 11pm and the inside of my car looked like daytime, I tried never to drive infront of you again the whole rest of that trip
those were some REALLY bright lights
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
That was going to be my next question if it lights up the road good without blinding people or getting pulled over by the cops. and is it d.o.t. legal? and could you get the same results comparable to a vehicle with normal sealed beams? I got an 3 complete sets of flip up headlights to try it out on.
Never once got pulled over and I spent some time in Canada and drove around the USA (10k+ miles) and never once got pulled over for them. Got flashed once or twice, but wasn't constant. They are VERY not DOT legal. They aren't the same as normal sealed breams, veyr different pattern. I did the flood light type system, not a concentrated beam. The flip ups have nothing to do with the setup, my flips ups were modified in no way.
thanks. i have located lights and took measurements i think i could make it work with the bezel routed out.
the plastic bezel around the headlight you can hog out a hole for lights making it look factory. I found a light that is 1" by 6" that uses H-3 bulbs so i also found a 1" by 3" fog lamp to fill the rest of the bezel. the bezel to use is the 82 to 84 firebird bezel which is just over an inch thicker and 10 inches width for the lights. I found this pic to help me set it up.
![](http://i57.photobucket.com/albums/g219/bigdaddyvu/191601_846_full.jpg)
I'm not sure. but that came up when i was searching for the non flip up headlight conversion.
opps ohhh well i did that to mine. but i figured how you did yours after i molested mine.
![](http://i57.photobucket.com/albums/g219/bigdaddyvu/050707_20531.jpg)
![](http://i57.photobucket.com/albums/g219/bigdaddyvu/050807_14171.jpg)
![](http://i57.photobucket.com/albums/g219/bigdaddyvu/050807_14201.jpg)
![](http://i57.photobucket.com/albums/g219/bigdaddyvu/051707_16341.jpg)
I decided to upgrade the hood.
There are alot of things i want to do but just gotta watch the budget.
