What does this mean?
and is this why I can't access CC board?
Jess or Mike??
300
Error doing DB query userdata row fetch (non-session) : session_pagestart
DEBUG MODE
SQL Error : 1033 Incorrect information in file: './phpBBCC/phpbb_users.frm'
Line : /var/www/html/phpBBCC/includes/sessions.php
File : SELECT user_id, user_autologin_key FROM phpbb_users WHERE user_id = 43
DEBUG MODE
Simply put it means the database and the board software are having another lovers quarrel so the DB went on strike.
Happens alot for some reason, I think it's because of the board software version we use. Too bad it's not compatible with any other version from what I understand. I might take some time one day and try to play with an old copy of the DB and see if I can beat the newer version of the board into working with the DB.
Car: 2001 Camaro SS
Engine: Almighty LS1
why don't you guys try what I suggested the last few times it happened and try out ikonboard?
as far as I know it still allows for swapping the DB's between phpbb, etc.
just a thought though since phpbb never seems to be reliable on dsl connections and ikonboard seems to do fine
