how fast would a 290hp-320hp 305 do?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
since i will probably never get enough money to build up a 350 i was wondering what you guys think a 305 with about 300hp and about the same torque do
cuz there was an article where thats what they got.....and i was just wondering
i've got 3.73 gears...automatic.....with the stock 190hp and 240torque i run a 15.9(with a bog)
if this combo wont get mid 14's then i will just keep savin for the 350
14's are easy withthat kind of power. i was going 14.2's @ 96mph with about 220hp at the wheels(calculated, i never had my car on a dyno). i am sure you coudl see similar results if youcan hook.
later
tim
later
tim
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
my 305 makes about 300 hp at the flywheel. i have a 5 speed with 3.73 gear. my guees is a high 13 based on the cars I've street raced. Too bad i never got it to the track before the axle and tranny broke.
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
HOW MUCH WOULD YOU BE LOOKIN TO SPEND ON A 350? THE 357 WHICH I WAS GOING TO PUT IN MY CAR HAS LIKE 8 MILES ON IT ALL IT NEEDS ARE HEADS, OIL PAN, INTAKE, AND A CARB
Car: 1984 Trans Am
Engine: Vortec 355
how much u askin for it?
and would u b able to do like monthly payments?
Car: 85 s-10 soon
Transmission: th350
IM ASKIN $800 YOUD JUST NEED TO PICK IT UP. IT HAS A NEW CAM IN IT TOO. I JUST NEED THE MONEY TO FIX THE BODY ON MY CAR. I WONT BE ABLE TO TAKE MONTHLY PAYMENT BUT IF YOU REALLY WANT IT I CAN HOLD IT FOR YOU UNTIL YOU GET THE MONEY.
Car: 1984 Trans Am
Engine: Vortec 355
just incase u didnt get the personal message i sent ya
what i said was
what kind of cam is it
and what are the specs on it
thanks
what i said was
thanks
Car: 85 s-10 soon
Transmission: th350
I DONT KNOW WHAT THE SPECS OF THE CAM ARE BUT WHEN IT WAS RUNNING AT MY BUDDIS HOUSE IT SOUNDED LIKE A DRAG CAR. ILL ASK HIM NEXT TIME I TALK TO HIM IF HE REMEMBERS.
Fast355
12-02-2016 06:33 PM
