Approximate 1/4 mile time?
Car: 1991 Firebird
Engine: 383 stroker
I raced a guy that I worked with tonight in his Civic, that is stripped down to about 2400 pounds. But anyway, we raced and were dead even till about 80 where we had to slow down for traffic. Earlier he showed me a one of his time slips from a local 1/8 mile track and he ran a 10.1. My question is, does anyone know what kinda 1/4 mile time that might equate to? Approximately
Car: RS
Transmission: 4L60
it all depends on other stuff, I hit 10s when I pass the 1/8.
I beat a turbo talon to the 1/8 (I had a good launch), but he ended up beating me in the 1/4 by .9, go figure.
thatz a very very rought estimate though, it'll give u an idea of ur time but will be off, sometimes farther than others.. plus it really depends on the car, some cars have amazing top end and will be faster and in some cases its all low end power and run out of breath at the far end which will severely hurt there ET..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use 1.56 as a conversion number. Neither are 100% accurate. I suppose the 1.55 number would be better to use. It will usually give a much quicker time than what you will run. If you had to dial-in to the next round but didn't make a full pass then using the 1.55 number will give you a time so you won't break out.
Looking at a time slip here I ran 7.375 at the 1/8 and 11.489 in the 1/4. Using the 1.55 calculation I should have run 11.43 and the 1.56 calculation I should have run 11.50. The 1.56 gives a closer conversion number however if I used it to dial-in, I would have broken out.
All my timeslips show the same results. 1.55 says I should have gone faster and 1.56 is just a bit slower than what I actually ran.
You make your own assumptions as to what works best. If you only run 1/8 mile and choose the 1.56 number then when you actually get to a 1/4 mile track you can expect to run a bit quicker than you hoped.
evilstuie
01-09-2020 08:29 PM
