PAN HARD BAR AJUSTMENT
Looking for info on what height guys run there pan hard bar at? i run autocross an a circle track drags series.im looking to tighten up the rear just a lil..i have everything under the sun when it comes to aftermarket suspension
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: PAN HARD BAR AJUSTMENT
Panhard bar keeps the diff centered under the car. The bar should be relatively level with the ground so that the diff stays centered as the suspension moves up and down. With an adjustable bar, you can lengthen or shorten the bar to adjust the bar however there are no really good reference points on the car. Third gens are not symmetrical from side to side to get a good body to diff measurement.
Other than the advantage of an adjustable aftermarket bar, the best reason for an aftermarket panhard bar is stiffness so that it doesn't flex like an OEM panhard bar will do.
kaos420 (07-14-2022)
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The other advantage is to aid in centering your rear should you lower the car. A lowered car requires a different length panhard rod.
COTM Editor
Received 1,933 Likes
Car: '89 Firebird
Engine: 7.0L
The rear roll center changes with panhard height and angle. This has a big affect on handling.
https://www.bedfordspeedway.com/tool...t%20difference)
A good starting point for a lowered 3rd gen is axle side down about 1". That lowers the bar 1/2" measured at center of bar. That "Guest" guy in the second link below goes by many names on this forum (vettruck, SlickTrackGod, and more...). His crabby personality got him banned so don't bother replying to any of his posts to ask him questions, but the guy knew his stuff though (crew chief of a minor league professional race team) so listen to him.
https://www.thirdgen.org/forums/susp...ml#post1908550
https://www.thirdgen.org/forums/fabr...ml#post4874562
When you say "tighten handling", do you want the front to have less push, or make the back have less oversteer? It might just take a rear sway bar spring rate adjustment. If you don't have adjustable sway bar then sliding the bushings inward and outward on the axle tube can change things.
kaos420 (07-19-2022)
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Going off of their 10% rule, do you think this is overall length or center to center bolt holes? I'll need to check where I've got mine set at.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Center to center between holes is length of bar as installed in car. That's where the forces are considered to be applied to the bar.
8777gta204
10-16-2013 06:42 AM
