front springs
Car: 85 z28
Engine: 94 lt1
front springs
i want to put in new springs on the front of my 85 z-28. i have recently installed a 94 lt-1 and removed air and heat and interior. this car will be autocrossed. i think i saw some where that the factory springs are 160 lbs and 1le springs are 350lbs. does anyone know if this is right and what have you put into your car? thanks les
you may wanna give sam at www.stranoparts.com a call or email. he knows how to set these cars up very well. he can tell you all the spring rates and alignments.
later
tim
later
tim
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The front springs are no where near 160lbs, the rear ones are. The fronts are at least 450lbs.
An autocrossed car will need more spring than anything out of the factory, so you will have to go aftermarket. The spring rate will be at least 600, maybe higher.
My ride: 750lb front springs, 150lb rear.
ambainb
04-25-2016 09:21 PM
Mutillator
Exterior Parts for Sale
10-01-2015 06:05 PM
TA8487
08-11-2015 09:02 PM
