how do i apply a dyno sheet to the strip?
does anyone have any good sites or tips about how to apply what i learn about my power badn from the dyno to an actual run? i am looking for info about picking the best shift points.
thanks
tim
thanks
tim
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Usually you launch at or just under your peak torque. Shift at peak HP and the rpm should drop to around the peak torque for the next gear.
What are your peak numbers?
i don't hav eht esheet yet, i am gonna hit he dyno in about a month. i just wanted to see if i coudl have everything figured out before i hafta grudge race a bunch of people opening day.
later
tim
later
tim
The idea is to maximize the area under the curve. When your motor is at a point where it is losing power fast enough to mean that revving any more means a decrease in the area under the curve, that's the critical point. You usually want to hang on a little bit past this point to make sure you're in a good spot when you shift. My LS1 will rev to 6800 (rev limiter there) and only at 6600 do I get to a point where the area under the curve is decreasing. Therefore I shift as close to the limiter as possible without hitting it.
LT1Formula
10-08-2015 08:34 PM
Dragonsys
09-25-2015 03:51 PM
