Kinda Bummed...lol
#201
Re: Kinda Bummed...lol
I havent looked into it nor ever even bothered to mess with 700r4 governors but is there a rough guideline of how much weight gives what rpm to shift at? I always thought it was a trial and error thing and a pita so manually doing it was always easiest
#202
This may be the only thread here regarding this.
Skip ahead to post #22.
https://www.thirdgen.org/forums/tran...s-springs.html
It seems a tedious process.
#203
#204
Originally Posted by my hemi
I really think it's the rpms hurting the full pull...
- Rob
#205
So basically I left power on the table by not going higher in the shift points. Well time to shift it and see what it can do..lol
#207
The shop were our car was done he is moving soon so he will dyno it once he sets it back up..but I'll try it at the track and play with the different shift points and see what it does..thanks for the help guys.
#209
#210
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I wish I had the scientific knowledge to guide you on what to do, but I can only go from my recent experiences with my new build. I also agree you should shift higher. However, my next time out at the track i might try to shift the 1-2 shift lower than the 2-3 shift. I feel like I am wasting time above 6,000 rpms in 1st gear when instead I could have shifted into 2 and then gone through 2 into 3 sooner, thereby getting me closer into the meat of my 3dr gear powerband right at the finish line.
My current best pass was when I shifted 1-2 at 6,048 rpms and the 2-3 shift at 6,400 Most other passes, although they were just 1-thenth slower I had revved out 1st gear and had it on the 6,500 rpm limiter. I don't know if its normal to shift the 1-2 shift earlier compared to the 2-3 shift, but that is what i want to keep playing with. I have a B&M rachet megashifter so I can bang it into each gear. This shifter has been in the car for 14 years and is still crisp, solid, and relaiable.
#211
#212
You have the holley sniper right you know how to data log im.so confused on how to...lol .I use diablosport on my hemi cars that's even to use and data log compared to this...lol
#213
I see peak power is at 6000 but is essentially flat from 5800-6200. I most certainly would not shift at 6000 and give up some of that top end.
Then from data logs, I'd observe where 2nd gear picks up after the shift. I'm guessing with a 700R4 gear ratio that it'll be less than 4000 if the shift was from 6200. This is falling in below peak torque which is 4800 (but again more or less flat from 4600-5000). (6200 / 3.06) x 1.62 = 3282. Add something for converter slip. 10% ? So, with the higher shift RPM and crappy gear split, you're closer to peak torque rather than shifting early and having to accelerate into the peak for a longer period of time.
At least that's my take on it. The 2-3 shift has a better spread so 6200 (again taking advantage of that nice flat power curve) drops to (6200 / 1.62) = 3827. That's still 1000 RPM to burn through to get to the sweet spot.
By the way, bouncing off the limiter will always be slower...Move the limiter up a couple hundred RPM, set the shift light at 6200 and go. There will probably be a couple hundred RPM overspeed on the shift / shift reaction time so adjust accordingly.
My two cents there.
Now this is where a better gear split pays off at the track.
First transmission I ever rebuilt was a Muncie M22. That's the close ratio version.
First Gear 2.20:1 Second Gear 1.64:1 Third Gear 1.28:1 Fourth Gear 1:01
Imagine that RPM window. 6200 drops to 4600 on the 1-2. 6200 drops to 4800 on the 2-3...that's why these M22 equipped cars were fast at the track and made use of a peaky HP engine spec.
The engine from the graph above makes a lot of power. Use it.
As for hemi, totally yes. Get in on the dyno and get a printout. Don't be too concerned about the actual number produced as chassis dynos are notorious for being left, right and centre. It's where the peaks are that are important.
But the best test, as has been pointed out is to get out and race. Experiment. don't be afraid to go slower. You'll never know otherwise.
#214
As for the PVC, how do you have your lines running? From and to? And the breather is where?
I had an issue with a lot of blow-by on an worn out engine. My fix was a oil separator / catch can between the PCV valve and the intake manifold / carb base. It didn't collect a lot of crap, but it did work.
#215
1.67 is impressive. Especially with a soft start. Yep. Slicks. Maybe a little footbrake action. As ZMAN pointed out, the highest flash stall generally comes from mashing the throttle off idle. In bracket racing this will mean adjusting your reaction accordingly. But for test and tune, it makes little difference. Unless it's the driver being tuned.
I hope it's not blow!!! The breather is in the passenger valve cover and the pcv is on the drivers side going right into the first performance TB I think its in a bad spot the hose was wet...I bought a catch can so im.going to run the pcv to the catch can the from the catch can to the TB think that is ok?
#216
As Justin rightly pointed out, the only way to know if it works, is to test it out. Met up with two members on this board yesterday not too far from us Gerard, both running Z28's. They are down to run at any track, as am I. Lets put this together and all meet up somewhere, Island, Atco, wherever. Not out for blood lol, this is all in fun, so no sneaking to the tracks without us...
Trying to get my buddies from NYC to join us as well, but I need an actual date to work with...
- Rob
- Rob
#217
Personally, I'd like to eliminate it altogether but that's not entirely practical. Especially for a multipurpose vehicle such as my own.
#218
- Rob
- Rob
#220
Originally Posted by skinny z
Personally, I'd like to eliminate it altogether but that's not entirely practical. Especially for a multipurpose vehicle such as my own....
- Rob
#221
Just do what I did, no catch can even needed because you'll be grabbing the blow by from a lower source. Run -10 or -12an oil line from block off plate to fitted passenger side valve cover, then run another PCV on the passenger side that also goes to the throttle body, but attach it to a timed port (charcoal canister port), not a full vacuum like the drivers side. The passenger cylinder head becomes the catch can. Works well....
- Rob
- Rob
#222
I know were eventually going to the MTs but my wife is a little stubborn she wants one more go with the nittos she is going to try going thru the water box and heating them up a hell of alot more...lol
#223
we dont have a timed port anymore the new revision TB got rid of it...lol it has only consistent ports...
- Rob
#224
It doesn't have to be timed. I chose to use a timed port because the drivers side PCV uses a full manifold vacuum port. You can use a full vacuum port on the throttle body as well if need be. All that is needed is the fitting to be added to the passenger valve cover. I'm running standard chrome valve covers, so drilling and tapping into it with the fitting was no loss...
- Rob
- Rob
#225
Take your dyno data and put it in excel. Rpm and hp columns
then based on gear ratios, and converter speed/slip, you can get an idea how much rpm drop there will be on the shift. Account for slip a few %
from that rpm range, highlight the cells off your dyno information between that rpm range in your hp column. Excel will display the average. Find the rpm range that has the highest average that is where you shoild shift to see best times
#227
Only one on my phone, you can see the rest when we get to the track lol. You just need to buy a block off plate with AN fitting already in tact. Rest is very easy...
- Rob
- Rob
Last edited by Street Lethal; 09-24-2020 at 12:44 PM. Reason: Reducing Size of Picture....
#228
Your getting very technical let me learn how to data log 1st...🤣🤣🤣🤣
#229
Car: 1987 IROC-Z
- Rob
- Rob
Let me come play too! I'm very close to Island dragway, but I was thinking that since I have never made a pass at Atco Dragway, and the owner is thinking of selling/closing the track.. maybe I should get to Atco one day in the next few weeks and make some passes. Probably for a test and tune day/night.
#230
We might be hitting island soon maybe even next weekend..
#231
I have done a bunch of reading on this. Yes, start out with a governor that started out the closest to where you want to be, in most cases the Vette governor.
Those that have tried to make a low rpm governor achieve the correct higher rpm shift points had very limited success.
#233
#234
My research shows 5200 rpm.
https://transmissioncenter.net/shop/...sq-wt-6-8-cyl/
#235
Car: 1987 IROC-Z
gotcha. next weekend I plan on going to two car shows actually so I can't squeeze racing in that weekend. I know a few friends gong to each show and I told them I'd be going, so I don't want to back out from that.
Saturday is the car show in Mount Olive for their F.O.P. fundraiser
Sunday is a car show at Nielsen Dodge in East Hanover.
however, the following weekend, I have no shows to attend, so I can plan on hitting Island or Atco
#236
Might be some info here.
At least, once you examine what you have at the moment ( and maybe your transmission guy installed a Vette governor) you can determine from that thread what it will take to move your shift points to where you want them. That's my take away from there anyway.
#237
#238
I know he used alot of the upgraded sonovax parts in the trans
I just downloaded the holley software and a sd card reader so I'll be able to data log soon..so I'll know exactly what its shifting at very soon.
#239
This is the mechanical fuel pump mounting area, correct?
- Rob
#240
Car: 1987 IROC-Z
nah, I never had facebook. I just do email, phone, and a very few car forums. you can PM (private message) me on here, or I can give you my email/phone contact info in a PM
I just checked Islands website and they changed all the events this weekend over to be Test and Tune events. unfortunately I can't go this weekend or next weekend
#241
Ok got the software downloaded to my laptop ordered the sd card reader now to go data log and see what this is truly shifting at..unfortunately its raining here so no test rides.. I really been wondering if this truly can do a high 11 pass im.told no that's all the car has In it..I feel it has a little more. What do you guys think?
#242
COTM Editor
Received 1,933 Likes
Car: '89 Firebird
Engine: 7.0L
Well I was told 1 it barely has 300 hp 2 it would never go low 12s 3 it would not 60ft good so were excited that it did all 3 pretty decent.. I'm correcting a few issues and figuring out data logging so I can fix any other issues that come up.. Sorry for being excited to see if a low budget old fashioned build might actually get into the 11s all motor..in a full weight car...
#244
Car: 1987 IROC-Z
you just gotta go and try it man. only a few weeks left here in NJ to get back to the track
there are a few photos of your wife driving the car last weekend at the track photographer's website
https://janscreative.photoreflect.co...spx?e=10593690
there isn't a way to save the photos, so if you like one, plan on buying one to support the track photographers business.
#245
Thanks for the info the pictures look great!!
#247
Agreed the few things were trying next time out is shifting...data logging and I'm having her go thru the water box to heat the tires she didnt Last outing were giving the nittos one more try they dont hook I have the MTs on deck..lol also I fixed the pcv issue went with a catch can. I'm bringing the other cold air intake pipe so I'll be trying different things..wish us luck..
my hemi (09-30-2020)
#249
Thank you !
I think this picture is pretty cool.
#250
Car: 1987 IROC-Z
Yep that guy takes pretty good pictures. I would suggest supporting his business by buying some photos in the future.
I know that you keep saying that the nitto radials you have on there don’t hook but I’m gonna have to disagree with you a little bit on that. If you’re getting a 1.6x and 1.7x sixty foot they are doing somewhat well. It’s not like you are frying them on the line and for 100 feet. If so your sixty foots would be much worse.
