Track and Street car build
#301
Re: Track and Street car build
After spending a lot of time figuring out the proper overlays for the factory gauges, my speedometer stopped working. Well these are what I really wanted to begin with just wasn't able to afford them. Still not sure I can now. But it's what I wanted.
#302
Haven't gotten around to the gauges or fixing the leaking intake manifold yet.
Been playing with my $750 beater. Removed a bunch of mangled old race car sheet metal to put on new race car sheet metal to go beat up. Haha... Before I hang it tho, it needs a trip to the truck wash to see the pressure washer and a squirt of paint on the cage and chassis. But it's fun not worrying too much on how nice this one is.
The following 2 users liked this post by Camaro51:
1986BANDIT (07-23-2022), Passmenow (06-17-2022)
#303
You should join us (race or spectate) this fall at the Big Willow Big Bore Bash, your car would fit right in.
https://www.vararacing.com/big-bore-bash
#304
Oh wow! Yeah that looks like an awesome event! Thanks for that. Ill push for race ready. But might not get that all done in time as work has me pretty busy. But I'd definitely like to take the car there even if just for show and see all the other cool cars/race cars.
#305
First step in trying to make the stock engine look a little better. Relocating the heater control valve and the smog air diverter valve.
Now you can see and remove the passenger side valve cover.
DynoDave43 (06-27-2022)
#306
I went a little out of order of what I want and need to get done. But I only had one day this weekend and I knew the airbox would be a days work. So there it is.
DynoDave43 (07-15-2022)
#307
Great job!
What's next instruments?
This O ring 2 ounce filter cover paper weight seems to stay tight.
They sell a shorter one for hood clearance.
https://www.bryansracing.com/
Too big to go down the carb .
#308
Thank you. Next I want to do the instruments, BUT... I need to pull the intake manifold as the front corners are weeping coolant. I don't need that to get worse. And while I'm there I got some roller tip rockers for it and new pushrods. Also a new distributor, coil and plug wires should be here Tuesday. So that's the next job. I'm planning for next weekend on that.
Thanks on thumb screw style air cleaner nut. That's definitely something I'm going to be needing.
#309
Taking it apart now.
Glad Im doing this now. the intake gasket was not looking good. If I had waited much longer I think it could have gotten pretty bad.
Not too bad looking inside for as many miles as it has
Got the intake all cleaned up and repainted. Throttle body is clean and ready to go. Gotta get up early tomorrow to start putting it back together.
#310
Most of the way back together. Probably would have gotten more done if I wasn't out so late at the races last night at Orangeshow Speedway. But gotta get my fix.
#312
Spark plug wires loomed by zip tie. Valve Covers fit
Some heat wrap replacing the stock crappy plastic loom.
Even with the stock manifolds I think it's looking pretty good.
The following 3 users liked this post by Camaro51:
#313
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
thats looking fine.........i love your car
spoiler and my home made hood pins(stainless ,made on a lathe at work)keeps my twisted glass hood looking somewhat straight......ive just been driving the hell out of it
cleaned up the interior,upgraded the stereo so i have bluetooth and usb plus some serious volume...
picked up an MSD streetfire hei and taylor "full metal jacket" wires for $100..checked summit,$500 new for both
#315
Got it all back apart again. Gotta Time Cert the end intake bolt holes. So I took out the lifters and gave them a good cleaning just cuz I was there. I've got it all cleaned and ready to go back together now. Just gotta pick up the Time Certs from Specialty Fasteners tomorrow.
#316
#317
Ok got my Time Sert kit. Don't feel like doing it tonight so probably tomorrow. Then start putting It back together again. This time it will Torque down properly and actually seal.
DynoDave43 (07-25-2022)
#318
COTM Editor
Received 1,921 Likes
Car: '89 Firebird
Engine: 7.0L
I don't understand your air filter. That shroud is closed off and just starves the engine?
#319
It's kinda hard to see when the hood is closed in photos. But if you see here the pan extends over the top of the cowl with raised sides. And I've cut the hood seal to allow air in.
1986BANDIT (07-26-2022)
#321
All back together. Ran out of daylight, so one day after work I'll check the timing and adjust the valves. But should be close. The Time-Serts went in super easy. I was stressing over them as the corner holes I needed them were counter bored already. But it wasn't an issue.
Passmenow (08-02-2022)
#322
Drove it over to the Riverside Cars and Coffee Sunday morning. It sure drives nice. Sad I had the only 3rd gen there
DynoDave43 (08-22-2022)
#323
Since it's been too hot to be out side here at 109 with 40%+ humidity Ive been staying indoors. So I started playing with my new gauge cluster.
#324
So was having a sluggish starter issue. Especially when hot. Well I found previous owner had only a 10 gauge wire for the main starter wire and it is cooked on the starter end. So now it has a 1 gauge wire and the starter spins it up no problem cold or hot.
DynoDave43 (09-16-2022)
#325
Paint isn't done to put decals on the painted surfaces yet. But since I'm driving it some I thought I should at least represent for the guys that helped me the most on the glass in the meantime. Couple others I don't have small decals for, like Wilwood (but you can see their name thru the wheels.) And Five Star Bodies. Didn't get a deal with them, but they did go out of their way to get me panels that had been out of major product and out of the catalog since the early 90's.
#326
Drove it to work again today. Why not get some In n out burger for lunch. No cup holders. At least yet. So no refills to go haha
#327
Axle/Gears: 10 Bolt 2.73 Open
You really shouldn't build a race car without a cup holder. Racing one handed while holding a drink is dangerous.
Beater79TA (10-18-2022)
#328
Got the fine line tape out. Finally getting around to the white stripe. I'm stoked to get this done, it's really going to make the paint scheme look better. Also put the inside windshield supports back in.
#330
Got the masking all done
Scuffed paint and started priming and painting.
Still gotta go back and do the lower stripe on the sides. I just wanted to get the harder part done first.
#331
If you are in the area Saturday we'll have a couple 3rd Gens racing and many other vintage race cars.
#332
Having fun at Willow Springs International Raceway this weekend. Found the computer has a 85mph limiter on it. Gotta look into how to get around that now.
#334
Got to meet some good people out here.
And see some cool cars
Camaro51 (11-06-2022)
#339
Haven't gotten it in yet. Been super busy lately with working shows for the company I work for.
I plan on taking the car to the SCCA track day at California Speedway this Saturday so there's another killed day. Haha I'll get to it. I Really want it in the car. Ive got it sitting on the shelf ready.
#342
Got some good photos from the track photographer. It was fun driving it all the way there. The guy at the gate was shocked I drove it, and even more shocked I haven't been hassled by the police. yet...
So much fun!
Passmenow (11-13-2022)
#344
Pretty cool to park in the cup car garage at California Speedway for SCCA track days.
DynoDave43 (11-15-2022)
#347
Super fun day. Great people. But boy are Firestone street tires the wrong tire for this. I'll have to take my Hoosiers next time I take it out. When I walked to the back there was a black mist all over it. I thought it was oil until I swiped my finger across it and found it was all tire rubber. Haha oh well.
#349
Excellent photos, looks right at home!
2 different tracks in 2 weekends good job.
I think it's ready for race numbers. (at least at the track)
What number is your Camaro?
#350
Number is 51. Couple reasons why, back when I was involved in Jeep speed desert racing in the 1700 class I was randomly assigned 1751. So I thought I'd keep with that. Plus my dad's 57 Chevy stock car is number 50. So I thought the next consecutive number would be cool. Then I thought about it and I always loved the look of the #51 black Exxon car from movie days of thunder so I went with it.
So I think I really need a better transmission before I do too much more. It's not real happy with all that abuse. I'm thinking a tremec 5 speed for it. So gotta look into that now.
