What are you updating for the 2018 season
#51
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: What are you updating for the 2018 season
Nice man! What kind of boost pressure has that developed at those rpms?
#53
No major changes for this year, did add a wing to the back, not sure if I will make a difference in E.T on an 1/8 mile car. But the builder says it will make it a lot more stable.
Time will tell.
really just love the look of it, so either way I am good.
#54
Engine: 584
That looks really good! Who's wing did you use?
#55
Carl's Aluminum. lifetime warranty. under $400 to the door.
The owner left his number in the box and said to call before the install. He talked to me for over 40 minutes and told me I could call him anytime with questions.
You don't find that kind of service to often.
#56
Engine: 584
Very cool. Nice to know who to call when it comes time! I'll be sure to write his name down.
#57
Engine: 584
Here are some of my updates.
umi anti roll bar, viking crusader coil overs, wilwood dynalites, umi camber plates, motion raceworks chute mount, stroud 430, ect.
should help get things to hook and slow down.
still need to get over to the welder to finish the tabs on the rear anti roll bar.
now back to under the hood to build more horsepower lol
#58
Engine: 584
More pics
#59
Engine: 584
The mess hahaOne of these days I'm going to pull the reared completely out and repaint lol
#60
Engine: 584
Chute lever
#61
Engine: 584
Updates to the nitrous lines.
#62
Engine: 584
Did you adjust the umi bar per their instructions? Just curious since I am adjusting this bar for the first track outing and wondering about the preload adjustment. Right now I have the bar neutraled and with just a slight amount of preload to the right side. This also made the scale weight the same on both rear tires.
#63
Installing a sbc 421 (dyno'd at 686hp)
Installing manual brakes and steering
Later in the summer installing a powerglide good for over 1000hp
Hoping to be well into the 10's on motor
Before the end of the year I am buying a guardian nitrous plate from Inductions solutions and hoping to be well into the 9's or high 8's by the end of 2019
Lots of work left to go
#64
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
#66
Car: 1991 Camaro RS
Yes I adjusted it just as umi instructed. It worked right for me. You can always find tune it once you make a pass. Have someone video your launch so you can slow mo watch it and see if you need more preload in one side or another.
#67
1 Post
Car: 87 Iroc
Engine: Ls 428 F2
Transmission: Th400
Axle/Gears: 3.70
The Car is running and today we went to the Dyno!
Now with 60/38 gears on the Procharger setup it maid 1123rwhp
cant wait to try it on the 1/4mile!
#68
COTM Editor
Received 1,941 Likes
Car: '89 Firebird
Engine: 7.0L
Yowza!
#69
Engine: 584
Nice man congrats, Those are stout numbers! Cant wait to see some 1/4 figures!
I haven't updated this for a bit but right now I am building a QFT 1050cfm 4150 carb to put on the car.
Also after reviewing many logs I found that with the way the car was wired I was experiencing a .400-.480 delay from the release of the brake until the activation of the nitrous. This was due to the progressive taking that long to fire up and get its bearings and begin its cycle when powered up off the relay.
I am thinking this was a contributor to my "soft" 60 ft times. Averaged 1.39 60's but run out the back door right at 150mph, I am thinking this should really wake it up.
Trying to get all the bugs ironed out before going to the heads up race in july.
Also the car is getting a 10lb safecraft fire system. This will go far to put both my mind and my families at ease while having a fun day lol
#70
1 Post
Car: 87 Iroc
Engine: Ls 428 F2
Transmission: Th400
Axle/Gears: 3.70
we tried some 1/4 this weekend but the ignition retard didn’t work(my fault of course) and at the limiter it killed the 2 belts that we had!
Now im putting my super pulley back on the head unit and a bigger pulley on the crank so it’s the same blower rpm as it was on the Dyno. And with that setup we can use the belts we ran last years and with them there has never been an issue.
next time racing is in a couple of weeks but it’s the Swedish version of Drag week with 1/8 unprepared racing. So I don’t think we’re gonna see some records
here is a YouTube link from the Dyno:
it sounds killer!
When you get your nitrous to kick in directly your probably gonna see some very good 60s
#71
Engine: 584
You are very correct. With soft settings in the progressive to get it to hook those 10.5's it still went 1.33 to the 60 now that I have the delay gone.
Feffman
07-19-2018 07:32 AM
Feffman
South West Region
01-30-2018 07:41 PM
Trevor86TA
11-04-2007 03:46 PM
