Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
headers $2000 GOING Big Block!
Old 06-14-2021, 07:51 PM
  #251
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: headers $2000 GOING Big Block!
Ok.. so using the Exhaust hanger location (2 bolts ea both sides Parallel / across from ea other. making a Aluminum Bracket that will hold the Fuel Pump and filters..12AN line. this bracket will span left and right side. under fuel tank sorta.. 1/4" Aluminum Plate should be fine.. Line will be under the car.. inside the ground Effects. and under plastic panel in front wheel well. entering eng Bay from under the battery tray in front..this is my old placement for my NOS fogger set up back in the 90's. but this time. to a single Fuel Reg.. that will supply the DUEL Throttle bodys & duel Nitrous plates..
Old 06-17-2021, 07:23 AM
  #252
this is the 3rd and 4th set of A Arms I have had in hand to look at..Sphon on the left..and BMR on the right..
sphon 9 lbs endless adjustability. (your going to need that with Sphon) I tryed the K member for the stock steering set up...with 2 other sets of there a arms..
BMR 6lbs bolt in. align and run it.. basic A arm nothing wrong with that..
below..look close at the A arms..this was another trick set of Sphons. A arms...and the first set of there arms had the poly bushings..so yes tried all of theres.. in the end it was there K member that had wheel set back..and had the main tube had been cut on both sides to make room for the tie rods.. ya...nah..
Old 06-18-2021, 07:51 AM
  #253
Ok..Aluminum Fuel Tank is In.. fittings clear the rear trunk by 1/4". pig tail to the sending unit is done. going to use the power wire that went to the fuel pump to trip the relay and turn the Pump on.. so No fuel Pump Switch on the dash..(fingers crossed)
Filler neck is in also... (1996 Camaro Parts). just need to order a few 8AN O ring fittings for the tank breather/Vent that will run down to the stock GM stuff.
Below..with 1/4" to [size=13px]spare the Feed fittings are in.. [/size]can lay the lines in any Direction.
pig tail from the sending unit (wire wrap) and factory GM plugs set up..
Filler neck and Tank are now [size=13px]plumed[/size] in to ea other..
Old 06-18-2021, 11:31 PM
  #254
So with most of the big job clean ups. getting done.. it come time to install the front suspension..
Viking Coil overs. [size=13px]crusader model struts. with the Aluminum Big block starting with 175lb springs..
A arms with
[/size]Del-Sphere pivot joints. with a set of BMR poly mounts A arms on standby..
Wilwood 6 piston brakes
its been 7 years from the time I moved my Camaro to its new digs...in Hayden From Spokomton..AKA Spokane WA.
Old 06-21-2021, 01:41 PM
  #255
ok so doing the Dakota Digital resto cluster and added the 200MPH speedo (why not) with GPS.
always liked my factory Gauges. and always had them working..now even with the set Up..I get to keep them..and a few upgrades..
The following 2 users liked this post by articwhiteZ:
scooter (06-21-2021), Whitebird75 (06-23-2021)
Old 06-21-2021, 03:18 PM
  #256
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I really like most of their clusters, a lot of them have a very factory look and I like the upgraded capability with the factory look
Old 06-21-2021, 03:23 PM
  #257
just got the invoice $1110.80 (tax and shipping was $97) lol
Want this to be a clean set up..with just the basic of aftermarket Gauges.to get better feedback / info..
ya also have feedback on altitude..1/4 mile speed/times/ list is up there..lol
Old 06-22-2021, 08:48 AM
  #258
Getting close...to using the last of the bolts to put this bucket together!
Old 06-22-2021, 09:01 AM
  #259
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That's a good looking box of fasteners
Old 06-22-2021, 09:03 AM
  #260
Can ya spot the one I did not get Plated.....lol.
Old 06-22-2021, 09:24 AM
  #261
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
What. ever. are. you. talking. about.......
Old 06-22-2021, 09:27 AM
  #262
I did not get one of the Panhard bolts plated..(did not take) it out till I did the Gas Tank...But I did reblue it.. but the other PanHard Bars came with new Bolts..so its a wash..
Old 06-22-2021, 09:52 AM
  #263
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That was supposed to be sarcasm, lol sorry
Old 06-22-2021, 09:54 AM
  #264
sorry..up another 24hrs working on this bucket of bolts...
Old 06-23-2021, 12:35 PM
  #265
Ok. made the 70 mile round trip. to pick up more Paint supply's. to shoot the top of the radiator support. after I install the eng.. if I painted it with the eng bay..it would get nicked installing the eng (I just Know it)..lol
And dropped off the motor mounts to be....Yes chrome Plated...
summits taking back a few things I picked up in the last 3 months.. 0 shipping and 0 restocking fees..(I Love summit).
as I dont need the Auto Meter speedo and GPS..fuel level and trans temp..(I forgot I had the same temp gauge already)
Old 06-23-2021, 09:28 PM
  #266
Test fitting of more parts...this fix was easy..
So..working with Sphone parts...is like
[size=13px]beating[/size] your head Against a rock.. it feels so good when ya stop... but [size=13px]until[/size] then.. Like the [size=13px]reinforcing[/size] plates they make under the camber plates.. but in order to use Sphone parts ya got to fix them First..
in order to fit the Bracket they make to fit A Camaro ya have to open up the lower stud bracket.. place in a Vice and Pull to open them up by 3/8"
Now to get the stud long enough to get a nut on the end ya have to cut the welds only on the back stud. and install a new bolt 1/2" longer. then Sphone uses.
Now the studs fit..clear the camber plate base..NOTE this plate might be thicker the Sphone USES..so this is Just fyi Fix if using Spohne lower plates and Founders Strut plates.
also ya dont have to weld in the new longer stud..the fit is tight..I peen around the bolt hole..then Tap to fit the new stud.. and run her in..
(M8 1.25 Metric.)
note the front studs look like they will just clear the top of the nuts..when torqued after alignment..
the top bearings are held in place with 12point (chrome bolts of course)
bluegrassz (06-24-2021)
Old 06-29-2021, 08:07 AM
  #267
so some time off from the front end.. and working on the back end.. back 7/8 years ago. when I started this upgrade.. I did a mini tub on the car..ya know..remove the bump stops..move inner wheel well back a bit..well I did the driver side first..and after I FINISHED it up I moved on the the passenger side..when test fitting the wheels back on the car..i wanted to add another inch of room to the driver side (move the inner wall in more) as i could just get my finger in the room left for the tire...it was my first time doing this so by the time i got to work on the passenger side I cut more into the rib. thats in the forward part of the inner wheel well..(your not going to move it with a Hammer) so with it at 105 deg out side and nothing going on.. I added the room I wanted..
Pic Below shows the rib (black line mid) of inner wheel well above my filler panel I put in place. I hit it with a hammer 2lb. ya can see dents. it did not move
and yes..do not try to just remove the outer sheet/skin after removing the bump stops..just cut that crap out..its as thin and flimsy as paper..just replace it with 16ga with a slight bow outward to clear coil springs/coil overs..
anyway..that rib was to close to the 325/50/15's and I wanted more room..the lower part is OK.
I use 22ga sheet to make my panels..I tryed to make it out of 1 sheet..had it done..but I did not Like the looks of it..I had to form it with a ballpeen and Vice..in the end I used 2 piece to make the filler panle after moving the rib it (a pie slice if you will) from the rib..and then tacking the plates to the rib and the rest of the wheel well..then sealing with panel filler..paint and a thin undercoat. seen..just sprayed.. the top and bottom look like a sharp slope..but it thins out a bit softer then it looks..but its all done...AND FITS TO THE INSIDE PLASTIC.. now all the wheel well sits flush from the plate covering the springs to the front and back inner well..
Old 06-30-2021, 04:44 AM
  #268
back a few years ago..the test fit...
Below..see the body rib..just above the red carpet..thats what had to go..(pie slice) a chunk out..we did!
Old 07-03-2021, 11:23 PM
  #269
so had to cut the Spendles to fit the struts..did not want to paint..(POR15) today..will have to do a few parts so another day..
so just used Gun blue to cover the steel for now.
like a glove..
Old 07-03-2021, 11:34 PM
  #270
doing all the small stuff..fit this. trim that..as soon as the motor mounts come back from Chrome plating. I can set it up for the Front Plate..then start putting it all together..
Old 07-06-2021, 09:28 PM
  #271
motor mounts are back.. finish is show quality like always..Spokane Metel finishing. this lot was $250..about $100 more then I was expecting. BUT ..they do a Fantastic Job.
and its Life time..covered.
Old 07-07-2021, 02:40 PM
  #272
test fitting the radiator..wow..talk about close to the Idler arm mount glad I had 5x 20 AN fittings for this thing.. even with a 45 deg 20AN fitting..it is close..Earls makes a tighter short 45deg fitting. its on the way $77.
as you can see the fitting i have now is a bit to long.. (type of 45deg)
it put it to close to the idler arm for me..it fits..but i want a bit more room. as when the front end guy starts to align the car I dont want him close the the AN fitting..will also buy a 2nd set of camber plates. So there will be no marks on the chrome..then when i get home i can install the chrome units..and sell off the.. unless they like Pizza..and Know what there doing..
just using a good seam seal to run 2 beads on the bottom of the radiator. let it dry.= a bit stiffer then silicone.. and no need for rubber. + Its white..make sure it has low sag..if you order it.. the trans cooler will go in front of this unit..it also has a Fan. and will be set up to blow into the 2 fans on the inside..
Old 07-11-2021, 01:07 AM
  #273
Love plastic BBC's
and plastic th400's make this so easy.its like putting on socks... I would never do with out one ever!
Old 07-12-2021, 11:20 AM
  #274
steering box..and small stuff..did have to Up Grade to 1/2" bolts to the motor mounts..the ARP bolts are to small in diameter. and let to much movement when it was all bolted in..now nothing wiggles/moves..and no front plate yet..but having one made..AGR steering box.. 1 &1/4 turn lock to lock..test fit..smooth even with out the eng running it..picked it up used cheap..took it apart to have it plated..thinking I would Kit it and put it back together..but the parts inside are not Stock GM parts. and a Kit would not work/fit.. had to send it to AGR had have them make it new.. I like it..just wish sombody would make a Billet Aluminum Steering box..now that would be cool.. this thing is like 35lbs..
Old 07-12-2021, 11:49 AM
  #275
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You need a 600 series steering box, I think they drop 7-10 lbs
Here
https://turnonesteering.com/products...-9da7ef4f-a53c
or here
https://sweetmfg.biz/home.php?cat=20
Old 07-12-2021, 12:04 PM
  #276
cool thanks for the heads up..they are out of stock at this time.and not taking back orders..if i upgrade later.I will go Power Rack and Pinon... I have a place in town that can machine down the out side of my steering box..(wish i would have found them before I plated the box) they could have taken all of the crap off the box and taken the body of it down.. and make the out side of the box trick looking.. might have them do a stock box and see what it looks like.. a test run if you will I would have had this box taken down to the min..
Old 07-12-2021, 01:05 PM
  #277
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Oh man, I like those plated spindles
Old 07-13-2021, 03:18 PM
  #278
its a easy plate job..I did steering box spindles. brackets brake dust shields.. a tone of parts for like $60 ..put it this way I can do a Entire rear end for $60..chrome on the other hand? well just the mounts and the steering cap ran $250... (I was told it would be $180) think they are taking advantage of me now...lol) I always let them think there is more coming...
$250 to plate at this rate I might have to go back to work...before summer is over...don't want to...took it off to work on the car..
Old 07-13-2021, 06:50 PM
  #279
the new 20AN fitting is in.. and fits like a glove.. can install it without having to move the Radiator around to get it on and leavs room for the Idler arm.
Earl's Not as nice looking the red horse.. But fits like I wanted 100% and only paid $70 for it!!
bluegrassz (07-14-2021), MIB4X4 (03-02-2022)
Old 07-14-2021, 03:44 PM
  #280
cant use the Factory Fans (I wanted to) they work so well for me in the past.. but I do not have room.. the fan bodys are at 5.1/2" deep the power steering and alternator are 6.1/2 deep and run to close to belts and just not room for me to feel good about it.. so ordered this from the same place that made (made) my Radiator not just sells them.. wanted 100% fitment.. they tell me it's less then 3" deep total.. going to install the trans cooler and fan on the front side blowing inward ..and run the lines to bulk head fitting down under the support..
Old 07-14-2021, 03:53 PM
  #281
that.. means I will be cutting the upper mount to fit...(sad) I think it looks good..
will be cutting the Bowtie off of the back..(sad) to get it to fit the new fans..only after test fitting...
Old 07-15-2021, 11:35 AM
  #282
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Looks great Jeff
Old 07-15-2021, 04:51 PM
  #283
Looks great Jeff
thank you.. SCOOTER is going to the the Harness..Im still test fitting parts. the fans are the only thing I cant use at this time test fitting parts..I could use them but it would be to close for me..and I want 2 to 3 inchs from the back of the fans to the front of the alt and power steering pulleys. It will just look better I think. leave room to work and things to Move.
The front Plate I want made I want to run under the Balancer/front of Pan. and not bolt under the water Pump.. using the 4 large bolts on the front of the block Ea side of the timing belt..they make them like this for sprint cars..just want it made for me and the BBC in My Camaro..simple and it works..this is a ball park shape. will span from inner fender frame rail/side to side.. and go over the steering box..
File Type: html
Old 07-15-2021, 05:17 PM
  #284
Received update on the fans/Shroud. should be to me by Sunday.the 18th lol Fedex on sundays..we will see..on its way anyway..($309)
I want to just bolt every thing in..All the parts are just setting...but I know if i do..ill have to take parts back off to move something..sucks.. I could slap it together as it sits...I took the summer off to get this thing done...want to start it up by end of July.. tick tock tic tock..now i will have to push things back by another week..Have to take 5 days and move the mother in-law to town from out of state..will take me that long to make some small repairs to her new house.and drive the truck to town.glad she could get a house..cash deal.. closes in 2 weeks..
Old 07-15-2021, 05:26 PM
  #285
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I took the summer off to get this thing done...it to start it up by end of July.. tick tock tic tock..
I guess I better do this weekend then, heh
Old 07-15-2021, 05:34 PM
  #286
you still have a few weeks..I have to move the mother in-law to town.. will take a full week the end of July.. just have the parts in hand for the 1st or 2nd week of aug.. I was Volunteered to drive the moving truck.. from OR to ID its a 1 day drive.. 8/9 HRs.. but i have to make some small repairs to her new house.. 1/4 mile from our house..sweet.. love her.. brother in law took the Vaccine and dropped dead 5 days later in the yard..3 months ago..she wanted to move to Idaho as we are the only Family My wife her Daughter has left..so mom is coming to town..it was close getting tight/fined a place under $300.000 and close by..we have room for her in house..but we all have lives..ya know....
Old 07-17-2021, 05:19 PM
  #287
working on the front plate mock up to get it Machined..going with 1/2" plate then have it milled down to 1/4" in places for fitment. And looks.
have to add some Cardboard in a few places. to shape then when done.. lay it out and make one in 1 piece.. snug fit to body..then trim to fit..and polish.
what it will look like when done..but for a big block..the end OVER THE steering box will be a bit Different..as I have to make room for the Hoses.think of a Arch over it.. and My aluminum Oil pan needs a bit more room in the front.part of the 1/4" milling im getting done..
Old 07-17-2021, 06:01 PM
  #288
trick looking
bluegrassz (07-19-2021)
Old 07-21-2021, 06:02 AM
  #289
so the Fans and shroud came in. and fits 100%.. might have to upgrade the fans to get over 3500CFM.. but will try them out to start with..there is room for 2 x13" fans..the 2x12s they sent me look small. Any way they do free up more room in front..All fasters are Button Head SS with Nyloc nuts.
I used seam seal on the bottom.. sort of a tough rubber hard rubber type stuff.. no need to cut up mounts..set to the Hight ya want with a bead as thick as ya need..let it sit over night..and then try it. if it's to High..it can be take it down with a flapper wheel.. its a cleaner install. And will never just fall off..
the thing with the seam seal is it has low sag rates. so it will be in the same place ya put it the next day.. ya can get it in black and white. even Gray..
Old 07-21-2021, 06:22 AM
  #290
the trans cooler has its own fan..was going to try to place it In front of the radiator. with its lines ending in bulkhead fitting under the battery try..(ballpark) then run back to the trans. this way it don't have to play with anything up front If making swaps..(if need be)..
Old 07-21-2021, 06:53 AM
  #291
with all the work done to the radiator support. I just hate to cut it..would like to take it to the shop and have one done in Billet..to the exact fit..but that would take another 2 weeks if I was lucky.. so..the
with all the finish work done it looks nice..but the Bowtie will be getting cut from the support. and just a lip left to hold the top of the Radiator.
I did not Make this..all I did was work the welds out and have it polished..wish I could save it...(the bowtie) it's sort trick looking..ya dont see it..at first..it sorta gets missed..
Old 07-26-2021, 08:00 AM
  #292
the support is fixed..
scooter (07-26-2021)
Old 07-30-2021, 11:23 PM
  #293
so getting rid of the 5.7 emblem on the rear bumper.
Old 07-31-2021, 02:09 PM
  #294
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
lol
Old 08-01-2021, 12:49 AM
  #295
had 2 made...this was the G rated one.
Old 08-02-2021, 03:05 PM
  #296
did upgrade to 13 amp SPAL fans..want to make sure the CFM is there.
Old 08-03-2021, 04:58 PM
  #297
DIGGLER's Avatar
This thing is really coming together, im ready to see the engine in there!
IROCZman15 (08-03-2021)
Old 08-03-2021, 05:15 PM
  #298
had to take all last week. to move my mother in law. to town.. from Springfield OR. to Hayden ID. The 26 foot U haul would only do 79mph and held it there for the 8 to 9 hr drive..($300) in fuel.+ a pod is on the way .lol any way it was set to go in..last week.. tryn for this week..I have to go back to work On Monday..(dont want the Job) did not want to go back to work till Sept.. anyway.. maybe by sat..have to get it in..so I can get the last of the paint work done. to the top of the radiator support..in warm weather.. Scooter is set to the the new Harness. need to get a butt load of Relays for the Vac pump.. tranns cooler fan.. and the duel rad fans.. a lot of amps..need to get it in and done (I think)..
Old 08-04-2021, 09:06 PM
  #299
upgrading to lager fans More CFM (SPAL) had to also upgrade the shroud. so I don't see the 1st set of bolt holes.and larger fan holes another $160..lol
Old 08-06-2021, 01:16 AM
  #300
also having to open the 2 fan holes in the shroud by 1" in diameter. having to buy a 2nd shroud..as I cant stand the holes left from the 1st set of fans...OCD sucks!
scooter (08-06-2021)
Quick Reply: headers $2000 GOING Big Block!
